Spartan 228/232 Cam/Stock 241's/LS6 intake = 424/396
#61
Only thing I can figure is our dyno's here in KY are stingy as hell! I've got a Walbro fuel pump and stock 28#er's maxxed out on my 98 TA, it's not running fat either, thats with 0.90 Lambda at WOT! It only makes 393hp/381tq! But heavier than stock ran 11.59@121 with a 2000ft DA! So who knows haha.
#62
How would this setup be in a a4 camaro ? Stock 806 casting, 3600 converter 3.73 26" drag radial, 150 wet......
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Damian, I'm gonna hook up with you this fall to do heads, cam, gears and tune etc. I am slowly buying the parts I will need. Ive got a set of 243's from an 2006 gto. Do you still recommend milling them .015 and what springs do you recommend such as Patriot Gold, 918's? Thanks, Jimmy
#66
That particular car your talking about is def impressive though! 121mph trap speed out of a cam only car is stupid! Good work!
#69
Those are great numbers for stock heads and a modest cam.
Did you degree that cam at the ground in advance, or did you retard
the cam timing at all? Just wondering as the top end peak is up high.
#70
The answers you seek are already hidden somewhere in this thread sir. ![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
The cam isn't peaky. The scan/picture makes it seem that way. The dyno computer printed out the dyno sheet vertically instead of horizontally for some reason, so the graph is squashed together making the curve less broad. This car will light street tires up from a 3K rpm punch in 1st and 2nd gear.
#71
Just wanted to post up an update. The owner of this car just went 11.70's @ 121mph this weekend with this car with BFG drag radials on the stock 10 bolt. We'll be installing a 12 bolt/4:30's with a 28" tire soon, so we'll be expecting bottom 11's on a cam only setup with a stock intake, stock heads, stock TB, and stock MAF.
I'm sure he'll post up on it soon.
#73
I think I might have found my cam. I have stock 241 heads, stock bottom end, M6, bbk manifold,P&p TB, Slp lid and bellow 10 bolt with 3:42 gears and 125 wet shot. Race weight is 3700lbs. How do you think this cam will act with this set up? Also adding LT in january. Thanks
#77
had a custom ground cam I spec'd very similar to this.
228/232 110+4
Wanted something lumpy but not too big as giant cams are silly for drivers
Glad to know it was putting down decent #'s and wasn't a bust.
Those are great #'s Damian BTW as I just saw this thread....8 months later...![Bash](https://ls1tech.com/forums/images/smilies2/bash.gif)
Gotta love those 241's
228/232 110+4
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#78
Here's 3 options: (Cam Motion)
C33-712 LS Hydraulic Roller Camshaft; 228'/232', .578"/.578", 114'+4'; 2,200 to 6,200 RPM
C33-790 LS Hydraulic Roller Camshaft; 228'/232', .612"/.612", 113'+4'; 2,200 to 6,200 RPM
C33-725 LS Hydraulic Roller Camshaft; 228'/232', .646"/.646", 112'+4'; 2,200 to 6,200 RPM
#80
Yes i understand this. I read that it was on Comp's lobes. But since in however many crapload number of posts, no one has specifically said where the cam was acquired or what the full specs of it are so someone could duplicate it. I was simply offering an alternative. ![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
And do you think its a funny coincidence that the Cam Motion cams I quoted are very, very similar in specs to the above mention Comp version?
