Dyno'd today and WTF!!
Old Apr 8, 2010 | 10:32 PM
Bjorne043's Avatar
Thanks for the advice! I was already planning for cutouts!
Old Apr 8, 2010 | 10:36 PM
Damian's Avatar
LSX Mechanic
Good luck. From the looks of things you've got at least 30rwhp hidden in there with a few various finishing touches. Maybe more.
One last hint of advice. Sell the 85mm maf and put a stock one back on the car. It's not helping you at all with an LS6 intake, stock sized lid and stock sized TB. You still have a bottle neck before AND after the MAF, which pretty much renders it useless. Stock Fbody MAF's are good to 480rwhp or so before they need to be changed out IMO.
Old Apr 8, 2010 | 10:44 PM
Bjorne043's Avatar
is it harming me at all though? I have plans for a fast set up at some point in the near future so if its not necessarily hurting me now and it will give me gains in the future i might as well leave it!
Old Apr 8, 2010 | 11:11 PM
'Trust''s Avatar
Probably over kill, but you need to do a compression check. Driving 20 miles on larger volume injectors can easily wash your rings out.
You need that a/f up to about 13.2, get some good gas and plugs in the car and bypass that horrible excuse for a free-flowing muffler and you should be set. You aren't making 440RWHP with a 228R cam though.
M6 or A4?
Old Apr 8, 2010 | 11:18 PM
rice4eatingnotdrivin's Avatar
Originally Posted by Bjorne043
It was the same dyno it was originally tuned on
hey man if it makes u feel any better i put my car on my friends dyno just to see where it was at well it said 320... when it was tuned at speed inc it said 379... lol so in other words never listen to the numbers its there to tune .. all that matters is what it does at the track
Old Apr 8, 2010 | 11:29 PM
Bjorne043's Avatar
M6 or A4?
its an m6
Old Apr 8, 2010 | 11:56 PM
desertLS1's Avatar
I don't see what the fuckn problem is here, you said it your self, your running with mid 400rwhp Vettes, take it to the strip and run low 11's with your 385rwhp.
Old Apr 9, 2010 | 12:00 AM
desertLS1's Avatar
M6 or A4?
Why not? There are plenty of 228 or even 224 cams making well over 440rwhp with great flowing heads..
Old Apr 9, 2010 | 07:51 AM
Bjorne043's Avatar
Thats a great point, but I'll never run low 11's with an m6 and a stock 10 bolt!!!
Old Apr 9, 2010 | 08:52 AM
ScreaminRedZ's Avatar
registered user
I agree that 440 will be tough with that setup. Not impossible, but I wouldn't expect it either. I'll be curious to see what you guys find with it when you start playing around.
Old Apr 9, 2010 | 08:58 AM
firefighter813x's Avatar
Originally Posted by Damian
My thoughts:
-11.5 is very rich, but it's not going to pick you up 60rwhp so don't get your hopes up. (That comment is geared towards your hopes of 440rwhp)
-Driving on larger injectors for ONE mile is a no-no, much less 20+ miles. You can easily wash the cylinders out doing that. More than likely your plugs are garbage at the very least.
-Your 85mm MAF might look cute in your engine bay, but if your "tuner" hasn't scaled the MAF properly (and it appears he didn't) your fueling will be all over the place and it's doing you more harm than good. Hence the reason he's trying to command 12.8 A/F in the PCM, and it's giving you 11.5.
-Flowmaster mufflers on F-bodies flow as about as well as Obama's political views. You're easily giving up 10-15rwhp in this department alone.
Put a $35 cutout on the car to bypass the shitty muffler, change your plugs, have your tuner (if he knows how) scale your MAF properly ON THE STREET, and then tune the car ON THE STREET. Then, strap it down and make adjustments for your internet dyno #. Good luck.
I like this answer... lol Good luck brotha. I've had similar issues too... I installed a tighter converter and a ported 90 on a cam only setup and gained very little. It was worth the try because the fast was cheap and I made money off the LS6 intake. I have seen many stock LS6 headed cars with a 224-228 cam make awesome power...
Old Apr 9, 2010 | 08:59 AM
  #32
I found your problem... it's a '98. Mine was a '98 too. Damn Bastard year.
Old Apr 9, 2010 | 09:20 AM
  #33
Cam only 228r M6
https://ls1tech.com/forums/dynamomet...o-results.html
A vette on a DD dyno...
https://ls1tech.com/forums/dynamomet...e-doctors.html
mid 400 seems to be the average with TSP 5.3's. I couldn't find many LS6+228 combos but I know they're out there. A few TEA and TFS/AFR combos were consistently higher. Just trying to help!
Old Apr 9, 2010 | 11:45 AM
  #34
Bjorne043's Avatar
^^Those are the types of numbers i was hoping for. And yes, 98 computers suck!!
Old Apr 9, 2010 | 11:59 AM
  #35
edcmat-l1's Avatar
A dirty MAF will NOT make a car run rich, it will make it run lean, every time. The dirt insulates the hot wires and fools the computer into believing the engine is ingesting less air, not more.
A tune that still has the long term fuel trims enabled, will richen up over time, if the tune is not dialed in correctly. This is the most likely cause of your now rich condition.
FWIW, there's nothing wrong with the 98 computers. I have no problem tuning them. There's a little less resolution in the tables, and of course they have a backup VE, but I've never had one run bad just because it was a 98 PCM.
Old Apr 9, 2010 | 12:04 PM
  #36
kinglt-1's Avatar
I agree with everything in this thread but the flowmaster muffler. There was a thread in this section of a guy making 430whp or so thru the flowmaster muffler. He opened up the cutout on the same dyno and it picked up 5-6whp... it was a heads cam setup similar to yours, so that is definately not were all your missing power is to be had.
Old Apr 9, 2010 | 12:07 PM
  #37
baalic's Avatar
And when I move to Florida, this is why I will take my LS1 to Virgina Speed for tuning and upgrading, since I have heard nothing but amazing things!! LOL Given Texas Speed is only 2 hours away so I may start there but I wont live in texas much longer
Old Apr 9, 2010 | 12:41 PM
  #38
NSSANE02's Avatar
Originally Posted by squirts11
Lol. That A/F ratio is pretty far from the ideal 13ish you want to be at WOT. Also, knock can drastically reduce hp since it's pulling timing. Get those issues resolved (it'll need to be retuned if you haven't done so since adding H/C) and you should pick up noticable hp.
That.
And that.
...and that.
Yup, take it to the track while the tune is off, running rich, and has possible knock... great idea.
Old Apr 9, 2010 | 12:53 PM
  #39
Damian's Avatar
LSX Mechanic
Thank you.
There's nothing wrong with 98 cars. I think that's just a common crutch a lot of people use when a car doesn't make the power it should. I've had no problems making power with 98's. Their PCM's arent as "tuner friendly" as all the newer models/OS's, but they still work just fine.
Old Apr 9, 2010 | 01:22 PM
  #40
SAPS's Avatar
If you're keeping up with Vettes, then you're making power despite the dyno. I'd imagine the weight diff btw u and vette is at least 400 lbs.
I have the same heads as u with a 224/230 cam...i put down 391 through a vig stall unlocked. I don't have any 1320 times but does 0-60 like a raped ape. About 3.8 on street tires according to the g-tech.
There are a LOT of happy dyno's out there.
