So close to 700 rwhp
Old May 26, 2010 | 08:27 AM
SSFAST's Avatar
Default Dyno numbers
Your car was dynoed on a mustang dyno or dynojet?
Old May 26, 2010 | 08:41 AM
02 BLK WS6's Avatar
Get it to the track. Dyno numbers don't mean jack until you back it up with a slip.
Old May 28, 2010 | 12:10 AM
52172's Avatar
Originally Posted by allngn_c5
Sounds like a beast !!
How long is your 10 bolt and stock drive shaft going to last though? Sounds like you need a steel 3.5" D Shaft and a moser 12 bolt to make the car bullet proof. Just don't go crazy until then.
Awesome power bro, very impressive. Was 700 rwhp your goal or something or are you happy with the power she made ?
How's the car drive? Have you already gotten on it ?
VIDEO !!!!
Do you have a cutout ? I'll bet with the cutout open you'll gain some power. That exhaust is not the most free flowing for an FI motor.
More like a MWC 9 Doug!!
Old May 28, 2010 | 12:35 AM
Detoxx03's Avatar
Thats damn impressive
Old May 28, 2010 | 07:04 AM
allngn_c5's Avatar
Whats up Frank ? Thanks for the 1 am txt message bro LOL. That was a rough wake up this morning after not being able to fall asleep afterwards. LOL. No later then 8pm your time bro. Glad you SS is still kicking *** !
SORRY FOR THE HIJACK !
Old May 28, 2010 | 12:41 PM
52172's Avatar
Yea sorry bro wasn't paying attention to the time!!! I'll keep it before 8 pm my time....
Old Sep 28, 2010 | 07:03 PM
jjcamaro02's Avatar
Originally Posted by jjcamaro02
Engine
346, Diamond pistons, Total seal rings, Compstar rods, stock crank, ARP main and head studs, Patriot 317 stage 2 heads, Epp blower cam, Ls6 intake, ported stock TB, 9.5 CR
Made 679 RWHP and 628 RWTQ
Procharger
D1SC, 7.65 crank pulley and 3.55 blower pulley, SD tune 2 bar, 15# of boost, EPP FMIC, Procharger truck intake with 4" filter
Fuel
Lonnies double pumps, fuel rails, feed line and return line, Siemens 80# injectors
Exhaust
SLP tuned headers and Y pipe no cats, Magnaflow catback
Transmission and rear end
FLT level 5 transmisson,Vigilante 4000 stall, stock drive shaft, stock 10 bolt with auburn pro series, 3.73 gears, Moser axles, aluminum rear cover
http://www.youtube.com/watch?v=DyIswZgHmKA
This pass was my best at 9.88 @ 134 with 1.31 60 ft. Would have had video sooner but had some tuning problems. And also poor 10 bolt broke after some 1.40 60ft runs. This was on 93 octane no meth with 18 degrees of timming.
Old Sep 30, 2010 | 04:42 PM
02NBMFormula's Avatar
I have a very similiar setup (ls6 heads, t56 and a 12 bolt are the differences) and hit 703rwhp. the difference is, your running killer times in the 1/4
Old Sep 30, 2010 | 04:53 PM
Carter01's Avatar
Very nice pass!
Old Oct 3, 2010 | 01:16 PM
fatmat80's Avatar
makes me want an auto congrats on the times!!
Old Oct 3, 2010 | 05:56 PM
fastlt1's Avatar
Was this vid with 10 bolt or 60?
Old Oct 3, 2010 | 09:30 PM
  #32
ExceSSive's Avatar
Originally Posted by fastlt1
was this vid with 10 bolt or 60?
+1 :d
Old Oct 3, 2010 | 09:41 PM
  #33
rem308winvtr's Avatar
dyno is a tuning tool its what you can put down at the track that matters
Old Oct 4, 2010 | 12:22 PM
  #34
jjcamaro02's Avatar
This was with dana 60, I only ran the ten bolt at the 1/8 mile track.
Old Oct 4, 2010 | 01:35 PM
  #35
PewterScreaminMach's Avatar
Awesome numbers and video. LOL at the 10-bolt. And what's the deal with the LS6 intake and stock ported TB? Room for improvement there?
Old Oct 4, 2010 | 02:06 PM
  #36
kinglt-1's Avatar
id be happy as hell with the results on that setup! a friend of mine went 9.85 @ 139 with basically the same setup but dart heads and a fast intake thru a th400 w/ transbrake.
Old Oct 4, 2010 | 05:21 PM
  #37
JPH's Avatar
JPH
Try taking the blower hat off, that should get you your 700rwhp easy. The cutout will probably only get you 5-10rwhp.
Old Oct 4, 2010 | 07:49 PM
  #38
fastlt1's Avatar
Did you order your trans with 300M Billet 2wd output shaft?
Old Oct 4, 2010 | 08:36 PM
  #39
gruntwork's Avatar
Awesome numbers and track run! This is the direction I plan on going with my car.
Did you get your compression that low with only the 317's or with the shortblock, or both?
What tires (type and size) are you running on the vid run?
Old Oct 4, 2010 | 11:01 PM
  #40
blue00ZZleeper's Avatar
Cutouts pick up A LOT of power on procharged cars...its proven lol...also add meth and bump up the timing a little bit. Are you getting any belt slip? That a awesome setup...I'm in the middle of a 370ci with the blower maxed on rpm with methanol...I hope to break 730+ but I'm also 6spd...which means no awesome times like your car lol
