Updated - 403 Race Motor with Dyno Video
Old 05-24-2010, 05:47 PM
CoopZ06's Avatar
Default Updated - 403 Race Motor with Dyno Video
After many months, the project is almost complete. After my last motor (347) which had issues from the start, my new 403 is almost complete. We are going to the dyno on Friday and hope to make 550RWHP and are looking for 9.80 ET at 138 MPH. Below is a list of modifications and your input is welcome. I will post Dyno numbers and charts when complete.
2001 Camaro - 25.5 Cage - tubed front end with strut bars - Car weighs 3200 with driver and fuel.
Transmission Turbo 400 - 5700 stall
Rear - Dana 60/4.11 gears
Engine - new LQ9 block
Heads - Trickflow 215cc, milled to 54cc and significant time hand porting (heads flowed 343cfm)
Pistons - Custom forged
Compression - 13.0
Cam - Solid Roller 258/262, 675/675 112LSA
Crankshaft - 4.0 Stroke Callies Dragonslayer
Rods - Callies Forged Rods
Jesel Shaft Rockers
Intake - Ported Fast 92 and port matched to heads (with dowel pins). We had to have aluminum shims made because intake would not seal on heads.
Headers - American Racing 1 7/8 inch stainless steel
This is a high level overview and I would appreciate your feedback.
Thanks,
CoopZ06
Old 05-24-2010, 06:40 PM
03 BUSA's Avatar
Why such a small cam for a race motor?
Old 05-24-2010, 08:28 PM
allngn_c5's Avatar
Sounds like all the ingredients for a race motor. Curious why you didn't get the new FAST 102 and port it, or did you already have the FAST 92?
Best of luck hitting those goals. 5700 stall, wow, she's gonna fly off the line !!
Old 05-25-2010, 09:55 AM
CoopZ06's Avatar
Thanks for the comments. The builder spec'd the cam, I'm just an accountant and weekend driver. I already had the 92mm intake from the last motor and would have liked to do a Becks sheetmetal intake, but my budget would only go so far.
CoopZ06
Old 05-26-2010, 01:50 PM
ONEBADWS6's Avatar
Sounds alot like my motor but my cam is a hyd roller.
Old 05-26-2010, 08:50 PM
ExceSSive's Avatar
I am sure that cam is big enough. Should make good power. Good luck!
Old 05-27-2010, 05:49 PM
HighspeedLean's Avatar
Subscribed.......very interested in how this turns out
Old 05-27-2010, 10:32 PM
ChucksZ06's Avatar
What did your builder use for springs for the solid roller. What diameter, seat pressure, etc. If you have that info. Sounds like a nice setup with the car weight I think you will realize your goals once it is dialed in.
Old 05-27-2010, 11:36 PM
52172's Avatar
cam sounds fine for a 403 race motor guys!!!!!! STFU
Old 05-28-2010, 10:00 AM
CoopZ06's Avatar
I just checked my invoice and it says the valve springs are Comp dual 944-16 (1.57 inch diameter). The open pressure is 755LBS and the seat pressure is 190LBS at 1.95 inches. We had to make the spring seats larger due to the diameter of the valve springs and reinforce the base with some type of spring seat cup. Hope this helps and I will post the graph when we are done with the tune. I did find out our reservation with the Tuner is now for June 2nd. Apparently there was an accident outside the shop where the tuning is done and some of the staff were injured.
CoopZ06
Last edited by CoopZ06; 05-28-2010 at 10:03 AM. Reason: left off diameter of spring another poster inquired about
Old 05-28-2010, 09:42 PM
ExceSSive's Avatar
Blast...I was looking forward to seeing some results today.
Old 05-29-2010, 09:39 PM
HuMi's Avatar
Compression - 13.0
Jesel Shaft Rockers
Thanks,
CoopZ06
You clearly made the wrong choice on intake. thats going to be your hinderance.
Old 06-03-2010, 10:55 AM
CoopZ06's Avatar
Going to the Dyno today for tuning and weather permitting, to the track on Friday. Should have numbers in the morning.
CoopZ06
Old 06-03-2010, 11:07 AM
LSxPwrDZ's Avatar
Sounds very very close to my setup and I have to agree that the FAST intake should be left to the stock bottom end guy's cause they are nothing but a bottle kneck for these bigger motors! Mine makes peak power at 6000RPM and with the cam I have in mine should be closer to 65-6700! I'm switching to a Vic Jr and Accufab 4150 and see what happens.
Old 06-03-2010, 11:40 AM
odarabla's Avatar
Can't wait to see the #'s man!! Good luck.
Old 06-03-2010, 01:45 PM
SlickVert's Avatar
Great!
Old 06-03-2010, 03:11 PM
allngn_c5's Avatar
So how big are the original 215cc runners with all the handporting? 343 cfms is good amount. My TFS 215cc milled to 59cc with no additional work are supposed to flow 328. You really went to town.
Old 06-03-2010, 08:15 PM
LSxPwrDZ's Avatar
That's pretty good considering my TFS235's flow sheet show 347cfm @ .600"
Old 06-04-2010, 10:05 AM
CoopZ06's Avatar
Default Update - Dyno on Saturday at 12PM
We had another delay but the car has now been delivered to the tuner and I have an appoitment at 12PM Saturday. I will video the final run and post up the graph.
The heads were previously milled to 54cc chambers (old motor). A significant amount of time was spent on the intake runners and chamber.
CoopZ06
Old 06-04-2010, 10:59 AM
allngn_c5's Avatar
CoopZ06
So is the runner more along the lines of a custom 225 cc or 230 cc runner now ?
Quick Reply: Updated - 403 Race Motor with Dyno Video
