LS1 SS with long tubes and hot cam dyno results
Hi,
This is recent upgrade on 1999 Camaro SS.
It has long tubes and now hot cam installed.
Can you check the results and let me know what you think about it?
RUN 1 is after hot cam installation.
RUN 2 is before that
Appreciate your comments and/or suggestions
I'm guessing KM is metric HP, If so the numbers are:
348hp/366ft-lb Before
373hp/380ft-lb After which is a gain of 25hp/14lb-ft
Since the numbers appear to have correction factors the comparison is probably pretty accurate.
I'm not too familiar with the LS1 hot cam but the curves are nice and final power output seems about right for a smaller cam only car.
Yes it's metric.
We think it's about what we expected however we were hoping for little bit more torque...
There is also C5 Z06 intake to be plugged in. Does anyone try that?
