2004 Procharged Trex M6 GTO
This is a friend of mine's car we just got everything all together to make a few pulls and take it to the track. I tuned the car with the procharger setup but I didn't do the previous N/A tune. Stock bottom end LS1.
Naturally aspirated mods
Trex cam 242-248 110 LSA (Not even close to a boost cam)
Fast 90 intake
New Era CAI
Pacesetter headers with stock exhaust
LS7 Clutch
New mods
D1sc procharger 9-10 psi (hard to make boost with 25 degrees of overlap)
LS6 intake with ported t/b
Devils Own methanol kit
Magnaflow exhaust with no cats
3.91 gears and aluminum driveshaft
60lb injectors with single walbro, need another one
2 Bar SD tune
Look how much torque it gained at 3000 rpm! 500 rwtq from 4800-5900 rpm, thats a Trex cam for ya lol. Now we all know this is not the right cam at all, he will be building a 408 in the near future built for boost. This was just to see what we could do with the LS1.
![](http://i60.photobucket.com/albums/h8/nitroused383/04GTOD1sc.jpg)
With a better 60' we will have his car in the 10's soon. Best pass so far is a 11.32 @ 126 with a 1.74 60'. 2200' elevation and 3000' density altitude.
http://www.youtube.com/watch?v=ztWKVR_0DQI
Fast 90 intake
New Era CAI
LS7 Clutch
New mods
2 Bar SD tune
I didn't think that cam would be good on boost but damn, the car def runs and makes great power. Sounds nasty aswell.
I think the only thing left to consider is ditch what looks to be the late 80's early 90's vette tornado wheels and get a lighter drag wheel setup.
It will go 10's on the current setup. AFR was at 9.5-10:1 at the track and he was only launching at 3800 rpm. He will be building a 408 which will have a boost friendly cam. For a 4000 lb car @ 2300' elevation 126 mph is moving out! Yes a better cam should help a lot. Last year the car went 10.9's @ 128 mph with a 1.55 60', he was running a 150 shot last year.
I really think the belt is slipping, it was making 9 lbs with the 3.8" pulley and now he's running a 3.4" and only making 10.5lbs. He doesn't really want to make anymore boost than that as we don't want to blow the stock bottom end yet.
Elevation really doesn't matter that much when you have 10psi...it isn't the same as a NA car...the correction factor is alot lower...
For reference,
from a 3000ft DA to 0ft DA on a NA car will gain about 4mph
while a boosted car from 3000ft to 0ft will see about 1.5mph gain
those are rough examples but check out dragtimes.com they have a generic calc too
For reference,
Of course I do agree, the NHRA altitude correction website says to only use half of the correction factor for turbo / supercharged engines. Basically if the car were at sea level it would make 1 more lb of boost, since we see about 13.6-.7 psi (94-95 kpa) of air pressure at our elevation.
This is a good little article too http://www.2-stroke-porting.com/altiden.htm
HPtuners logs with NGK AFX wideband showed 11.3-11.5 through the entire curve. The probe on the exhaust pipe was moving back during ever pull. Fun trying to tune a car that drops to 40 psi of fuel. Single walbro and 60lb injectors are not enough, even with meth.
I was out jet skiing for the weekend so I didn't get to see the car make the pass. When he told me it ran a 10.7 @ 129 I about crapped, it still has the street tune in it because I didn't want him to blow the damn thing up, the methanol pump has already quit on him atleast 4 times during a pass. Thank god I've absorbed some of the knowledge Frost has posted on the hptuners forums over the years or this thing would be a boat anchor right now.
