EPS cam, STEM 241's, Typhoon intake go 450/423
Old 07-15-2010, 06:41 PM
chrs1313's Avatar
I dynoed mine with dry ice behind the cooling fan...that's legal right...
Old 07-15-2010, 08:10 PM
Titanws6's Avatar
Originally Posted by Damian
I didn't notice the #'s were STD. Prob a 435-440/410 car corrected.
Bout time you got here, wadda you think....would this do pretty well with my set-up
Old 07-15-2010, 08:18 PM
Paint_It_Black's Avatar
Maybe, what's your set up?
450/420 - ish from 241's and that intake isn't bad.
Old 07-15-2010, 08:25 PM
Titanws6's Avatar
Stock 243s w/ sodium valves, dual PAC Springs, "el torro"
LS6 Intake, LS7 lifters, LS6 oil pump, LS2 Chain, Stock Ported TB, Pacesetter LTs, ORY, FM Merge, 2 OTL Exhaust,
4.10 stock 10 bolt...........Budget Built
Old 07-15-2010, 08:29 PM
Sounds good, I wish I had the 243's with the sodium valves! At least I wouldn't have had to fight the velocity profile over the short turn as much with the 243's..
Old 07-20-2010, 07:45 AM
AINT SKEERED's Avatar
Nice numbers paint it black, Eps cams are doing great and will be putting one in my Nova when i decide to take the old used Futral cam out that i stuck in there to get it going.
It was a cheap cam that got my engine running but is designed for strokers. Geoff has an idea of a better cam to get me launching a lot harder then this one . That is where my car is lacking is the hole shot.
Old 07-20-2010, 02:07 PM
desertLS1's Avatar
Strong numbers.
Those EPS cams are really showing some great results.
Old 07-29-2010, 09:38 PM
ryle's Avatar
makes me wish I had invested in an EPS cam... Oh well, Guess i'll see what kind of numbers my Comp XER281HR makes... If I'm not satisfied those numbers are making me think of switching over
Old 07-30-2010, 12:14 AM
Johnnystock's Avatar
What gear are you running and how is it on the streets? Nice numbers for sure! I need an EPS cam
Old 07-30-2010, 06:31 PM
Right now I have a stock 3.42 gear. Don't plan on changing it until I get a midwest 9" with 4.10's. Then some 28" MT radials.
It's a big cam. It definitely drives like a big cam. It could use the gear for sure but the tq is so abundant everywhere it's livable for now.
