Cam-only LS2 C6 Vette makes 503rwhp
This is one of the most thoroughly prepped cam-only cars I've had the pleasure to tune. It's a 6 speed manual 2006 Corvette with a stock LS2 short block. After adding American Racing Header 1 7/8" with no cats, Magnaflow catback and tune, the car put down 390rwhp. Strong, but certainly within the realm of what healthy LS2s make.
Next, the following items were added:
FAST 102 LSX-R intake (stock, unported)
102mm electronic throttle (yes, the big one)
MAF delete with 4" straight tube (no inlet restriction at all)
Calloway Honker CAI
ASP underdrive pulley
Patrick G custom 234/242 .602/.605" 112LSA +4 advance cam ground with EPS lobes
Yella Terra Ultra Lite 1.7 ratio rockers
Patriot Extreme dual valve springs with Ti retainers
Manton 11/32" pushrods 7.475" length (shorter pushrods were too noisy)
21 degrees of timing at peak torque, 23 degrees of timing at peak power, 12.5-12.8:1 A/F ratio.
Final results were: 502.945 rwhp/451.791 rwtq.
The way the EPS lobes carried power was a thing of beauty.
Calloway Honker CAI
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
The following users liked this post:
KwikbowtieSS (07-28-2021)
Regardless, very nice numbers. You seem to be able to get great performance from your grinds. I'm sure a lot of effort was put into this project.
How do you think this would work on a FAST 90/90 equiped LS6?
Yes he is. Great lobes. This is one of my favorite Patrick G custom high-rpm LS2 grinds.
The flattened torque curve is very common when running a cam with a lot of overlap coupled with the American Racing 1 7/8" headers. Typically, the curves you see are higher at 3500 rpm and lower at 4000 rpm, but with tuning, we were able to flatten the curve out. The steep climb of torque to 4800 rpm is a testiment to the well chosen valve events. It comes on the cam very hard!
The MAF delete was mainly because so few MAF options exist in the 102mm range. The stock 85mm MAF is way too small for a 102mm TB and large necked cold air intake. The stock MAF would have been a choke in the system.
The cam would work well in an LS6, but keep in mind the LS2 has 18 more cubes and another half point of static compression. Also, there is no denying the gains when you use the big 102mm throttle body on a combo that turns a lot of rpm. I feel that the FAST 102 intake with the 102 throttle body with the 4" straight pipe with the Calloway Honker were responsible for at least 40rwhp of the gains (vs stock). A FAST 90/90 would be down 10-15 (because of the added gains of the larger TB and MAF delete). An LS6 intake with small MAF would be down 25-30rwhp in comparison. Don't forget to take away another 25rwhp if running a 5.7L vs a 6.0L. Take away another 10rwhp if you don't have the stiffer pushrods and low friction Yella Terra rockers.
Yes, still stock clutch. It's not very happy, but it's holding for now.
__________________
1 Post
Hey Pat, this is one bad *** setup. I remember all the effort you put into your WS6 and made 507 rwhp. He's got a few cubes on ya but is running stock heads and managed to get within 4 rwhp. How do you think this beast would respond to a set of TFS 215's? Or another set of quality aftermarket heads ?
If he does add heads, what clutch would you suggest.
Not sure the clutch would hold any kind of launch considering its unhappy already, but I'd like to know as well.
Future clutch choice will depend on what kind of racing Robert wants to do. The street manners are so nice right now, I'd really hate to spoil them with a lighter clutch.
__________________
Hard to say because the cam was custom-tailored for the airflow of the stock 243 heads. Most top quality aftermarket heads gain more on the exhaust side than they do the intake. The ideal cam with TFS 225 heads (for example) would have less split between the intake and exhaust duration. LSA and advance would be different too.
__________________
