468ci with PI 275 heads/Harrop itb-- 710hp, 680tq--missing power?
It's taken 9-10 months to get to this point (I'd have to look at emails to be exact), but I finally have my engine built.
HKE built the longblock, on an ERL Superdeck short deck block, and Ed at Va Speed provided the ported Harrop and is in the middle of tuning it on their engine dyno.
I just hung up with him, and they did the WOT tuning last night and the engine made 710hp, and 680 ft lbs of torque. The engine is peaking at ~6k rpms. I'm ecstatic about the torque #, but slightly disappointed at the HP #. I'm not sure if I should be disappointed though, but as everyone knows, it's easy to get a # stuck in our head. When we don't get to that magic #, we start to question why. I'm not sure where the choke area is, and in fact how much of a choke it is. I'm guessing it's the Harrop, but I'm not sure how much is really left on the table. Ie: what would I gain by going to a carb manifold/tb? +'s and -'s going to a larger/different cam? I haven't gotten Shawn's opinion on the setup yet.
Engine specs:
Block: ERL Superdeck 1
Stroke: 4.250
Bore: 4.185
Heads: Performance Inductions 275cc Lsxr Titanium intake valves/ss exhaust
Intake: Ported Harrop
Cam: 247/255 112 + 2 .670 lift (int/ex the same) HUC lobes (comp cam lobe) hydraulic cam
Compression: 11.2:1
The engine is going in my Factory Five GTM now, so not the same hood issue as a Corvette or F-body.
Overall, I'm happy, but still can't wonder where the extra 40-50hp I was hoping for are. Any thoughts?
Engine specs:
Stroke: 4.250
Bore: 4.185
Compression: 11.2:1
Roberto,the engine is a really big engine and requires alot of air to run high rpm-the more rpm the easier it is to make hp.The Harrop isn't designed for a large cid high rpm engine.The cross section of the runner isn't small,but isn't big either.So your kinda limited on intake airflow.Would another intake flow more air-yes,but your going to sacrifice low end,and driveability.Can we make what you have better-probably.After looking at the dyno curve-the tq drops off pretty sharply after 5000rpm,what we need to do it get this to drop off much slower-this will make more hp at the same rpm.How can we do that?-look at things like compression and cam events to gain cylinder pressure and gain more power using the same limited amount of airflow we have available.There is no one solution-or an easy one-this engine is pretty much uncharted territory.
Our motor with the same size crank and a little less bore used ALOT more cam than that !
We made a good bit more power but ours is a race motor with a single plane intake.
Yours seems like its more of a street set up, there has to be a trade off somewhere.
I bet it will be fun on the street!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
More cam for sure....its probably about 8-10 degrees light IMO.
Big motors need alot more cam.....especially big smallblocks that usually have alot of airspeed.
I would try that first before banging your head on the wall and looking elsewhere.
Big numbers either way and the curve must be extremely fat with a lot of low midrange grunt.
Good luck hooking it up....LOL
-Tony
-Tony
I bet it will be fun on the street!![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
-Tony
-Tony
It's right next to your magic wand. ![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
I just spoke to Shawn, and he is thinking of what to do to max the combo out and maintain the Harrop. I hope to hear from him tonight or tomorrow, so hold off on the idle/drivability tune until we see what he comes up with please.
UNDER PRESSURE MOD
I just cracked up when I saw that. At work, I call it the CSI mentally when upper management asks why I can't get them results as quickly as they do on TV when they analyze samples.
I need to use this the next time I'm asked why it takes as long as it does to do a sample analysis.
Sorry, for the sidetrack, I thought this was histerical.
4.25 crank
4.155 bore
Cary's Mozez Heads and his intake.
Made 968hp
https://ls1tech.com/forums/nitrous-o...-ls-motor.html
Moderator
Borrow a different intake from someone else and dyno again. The intake is to small for that motor.
Since you have all that room in the back of the GTM a supervic with a 4500accufab TB would be killer. Might need a different cam to take advantage of the shorter runners
Tall Deck RHS block
4.25 crank
4.155 bore
Made 968hp
4.25 crank
4.155 bore
Made 968hp
I've been thinking of going that route. I could use the Harrop in my c6 (that was the original plan), or sell it. What would you guess the power difference to be?
