AES 442 stroker
Intake is a fast 90 with a NW 90mm tb. I did take the dremel to the large end of the ports to clean them up. A port match had been done for a previous set of heads everything was close except for the bottom of the port which was actually lower then the head so there wasn't anything that I could do about it. At least 1/16" lip
Weather conditions were not ideal it was 90 degrees, 994.5 mBars and humidity was 33%
There is another post which Fraser expands upon the build but this was by no means a maximum effort build the cam is a 244-248 615, 613 on a 114 lsa comp xer lobes. TFS 235 heads Callies rotating assembly.
So first pull was to 5000 rpm just to check afr and the engine made 505 rwhp 495 rwtrq.
Without to many pulls the car made 550 rwhp and 512 rwtrq.
The tuner felt that the 85mm maf is really a restriction, The way the vacum increased at about 6000 rpm also the maf had basically run out of callibration. He felt that with a larger maf or a speed density tune the motor had another 20-30 hp in it.
Personally I don't care I just love the feel of that big fat torque curve.
AES did just what I wanted but Fraser there is no way that thing idles like a Honda
and everyone that has listened to the motor cannot believe how quiet the top end is. There is no valve train noise at all.I also want to thank Arun who tuned the car. He spent so much time on the road tune and getting it right that it was 3 pulls to dial in the wot.
I know that this is a lengthly post but I wanted to answer all of the most common questions.
One other strange thing, dynoed with the cutout open. the last run closed the cutout and ran it through the stock muffler. It was only a 4 hp difference.
thanks
pics man.
