2000 Trans Am Dyno
Old Jan 31, 2004 | 02:19 PM
RESTOMAN's Avatar
Wink 2000 Trans Am Dyno
THIS IS A TRANS AM THAT WAS DYNOED
IS THIS PRETTY GOOD??
IT IS A 5.7L--WORN OUT ENGINE,THE GUY WANTED TO RUN IT UNTIL IT BLEW UP.
IT HAS A VORTECH ON IT-- MAKING 8-9PSI [HAS AFTERCOOLER]
STAGE II JD'S CYLINDER HEADS
JD'S CUSTOM 220 CAM FOR SUPERCHARGER
STOCK INTAKE W/EGR
STOCK EXHAUST MANIFOLDS
STOCK CATYLITIC CONVERTORS
38LB INJECTORS--WHICH NEED TO BE CHANGED IN ORDER TO FINISH TUNING.
WITH NEW INJECTORS AND FINAL TUNE SHOULD BE 550+RWHP
JUST TRYING TO GET SOME INFO--I WILL POST THE FINAL DYNO SHEETS WITH A/F NEXT WEK WHEN COMPLETELY FINISHED.
THANKS
JOE D.
I AM TRYING TO POST THE DYNO SHEETS WHICH ARE IN .DOC FILES AND IT SAYS THEY ARE TOO LARGE--ANYONE KNOW HOW TO DO THAT??
File Type: bmp
Old Jan 31, 2004 | 02:23 PM
H82BBad's Avatar
so what did it do?
Old Jan 31, 2004 | 02:24 PM
boomcase's Avatar
I highly dought you will even be close to 550 rwhp with that setup. Without headers and exhaust or an ls6 intake I think its impossible to be there. you maybe will get 450 but noway 550.
Old Jan 31, 2004 | 02:25 PM
VINCE's Avatar
Shorty Director
JD they are going to move this to the FI section. What did the car dyno?
Old Jan 31, 2004 | 02:26 PM
RESTOMAN's Avatar
Default Dyno
IT ALREADY DYNOED 530RWHP--RUNNING OUT OF INJECTOR AT 5500 RPM
JOE D.
Old Jan 31, 2004 | 02:33 PM
VINCE's Avatar
Shorty Director
Awesome..
Old Jan 31, 2004 | 02:34 PM
mike m's Avatar
are you sure it was injector? i have 38s still and they are fine. i had to upgrade my enitre fuel system to get fuel. put a fuel pressure gauge on the rail asap.
Old Jan 31, 2004 | 02:36 PM
RESTOMAN's Avatar
Default Fuel Pressure
FUEL PRESSURE WAS 60 PSI STEADY WOT--EASY ON ME I HAVE IT ON THE DYNO.
I 'VE MADE THE NECESSARY CHECKS FOR THAT.
THANKS FOR YOUR INPUT THOUGH.
650 HORSE POWER AT THE ENGINE WITH A 20% LOSS WOULD BE APPROX.520-530 RWHP WHICH I AM AT.
BSFC OF 0.6 -- DUTY CYCLE OF 90% --- FUEL PRESSURE AT 60 PSI WOT
WOULD BE AN INJECTOR SIZE OF 46+ FOR AN 8 CYL SUPERCHARGED ENGINE.
JOE D.
Old Jan 31, 2004 | 02:47 PM
fretwire's Avatar
We all can hear you, Mr. All-Caps.
Old Jan 31, 2004 | 02:48 PM
VINCE's Avatar
Shorty Director
JD our cars are funny. Most that tune FI cars without a mustang dyno's loading usually try to tune on the street first with a actual load and then tweak a/f on the dyno. I have seen cars dyno well on the dyno with the a/f dead on and blow a head gasket on the street. I know you know what you are doing when it comes to cars, but just in case you have not researched our finicky FI car setups I just wanted to share what others have learned tuning the FI LS1.
Scalpel's Avatar
Can you please refrain from the "CAPS LOCK". It makes me not want to read anything you post. I understand that some are not good with computers but please let up on the "CAPS LOCK".
Thank you
Old Jan 31, 2004 | 02:57 PM
RESTOMAN's Avatar
JUST MAKING SURE--DIDN'T WANT YOU TO MISS ANYTHING--
ANYTHING ELSE YOU HAVE TO SAY THAT WOULD BE WORTH WHILE???
thanks
Joe D.
Old Jan 31, 2004 | 02:58 PM
RESTOMAN's Avatar
Thank you
anything else you have to add to the tech thread??
just wondering levvi--
you guys are quick draw mcgraw on the ball busting--aren't we.
joe d.
Old Jan 31, 2004 | 03:01 PM
RESTOMAN's Avatar
thanks-- i have learned how to tune the a/f with my dyno.
i guess it really depends on what you get used to.a dyno is only a tool--some people just get used to different tools.
i have tuned many s/c cars,fi cars,and carbureted cars.
thanks for your input--i appreciate it.
at least you are trying to say something pertaining to the thread and technical.
thanks again
joe d.
Old Jan 31, 2004 | 03:04 PM
Scalpel's Avatar
joe d.
I was just asking if you'd refrain from it. As a peruser of this board I'm a potential customer and for me, the CAPS is not necessary and makes me not want to read the results, products, etc you promote. That's one less potential sale.
I'm awaiting the results too as this is what this thread was made to show. I didn't realize you were asking for our advice on how to tune the car for more power hence I didn't feel it was a "tech" inquiring post. That's why I posted no "tech" advice. I was just asking for no "CAPS LOCK" in the interim.
When I read it I get the impression of the highschool bully yelling at everyone trying to get attention. Your results of the power so far are great and would still be well received without the CAPS LOCK. I know you're excited, as are we, so all I ask is a cutback of the CAPS LOCK. Your results speak for themselves and don't really need an entire post of CAPS LOCK.
Old Jan 31, 2004 | 03:06 PM
VINCE's Avatar
Shorty Director
If you are at 90 percent duty cycle then you do need bigger injectors for sure. One of the first FI cars MMS did 2 years ago dyno'd 597rwhp with 42lb injectors and stock shortblock. MMS has since duplicated that with several C5's. The weird part is back then no one believed the #'s. Actually 2 years ago one of MMS cars dyno'd 450rwhp NA, but no one believed it. Now that 450rwhp is common on a NA car it is FACT. JD your numbers are great. I expect with bigger injectors and tuning you will see close to 600rwhp. Please keep us posted.
Old Jan 31, 2004 | 03:10 PM
Scalpel's Avatar
If you are at 90 percent duty cycle then you do need bigger injectors for sure. .
Yep, 90% duty cycle is approaching the dire limits. Too risky however the owner said he wanted to run it till' it blew up
Might as well give the customer what he asked for
Old Jan 31, 2004 | 03:13 PM
VINCE's Avatar
Shorty Director
LOL!!! If Rob Raymer can keep 750rwhp from blowing up a stock shortblock. I think JD can manage to keep this car running.
RESTOMAN's Avatar
vince--i will need intake and headers to get to that though--i have to see if the guy wants to go for it.
supercharged cars do require more fuel than n/a cars-you can see that.
take it easy
joe d.
Old Jan 31, 2004 | 03:15 PM
Scalpel's Avatar
Can't argue with you there
