HKE 468ci Chassis Dyno Results...
It was...but I decided to put it in my c6 at the last minute. Erik is building another motor for the GTM now.
#37
The specs for my new motor have changed 4 times since I dyno'd this thing. But it will be big bore/big stroke with a top end to feed it for sure. I was 100% going with the Mozez top end, but Erik has had trouble getting pricing and info on it. Truthfully after seeing how much power this engine is making with cathedrals, I'm 2nd guessing if the Mozez is necessary for what I want to do. In fact, I would be happy with a mirrored engine in the GTM. It's unreal how fast it revs and how far it carries out the power well past it's peak.
The Harrop is etc (they have 2 versions). Again, you would need their adapter for the ls7 port, but I've heard the adapter actually makes the manifold perform better if you can believe that.
Thanks
I'm more happy with the idle than the power believe it or not. If I stuck a Supervic or 4500, it would peak later and dyno much higher HP (I doubt it would make more torque though). My top concern from day 1 was idle quality with a huge cam, and that's why it won't see a carb style manifold.
I can't wait either. HKE is the best. I'm trying to do the one he building now less custom so it doesn't take as long waiting on custom pistons, crank, etc.
#38
Need to post hp tq dyno with equal scales so the TQ doesn't look so funny! Tq curve is actually much flatter with equal scales. The dynojet software made different scales for TQ and HP exagerating the TQ so it looks really crazy.
