Kaltech Single plane 502 rwhp n/a 346
holy rpm batman...hold on for your lives little bearings...haha
very nice setup top end screamers for sure...but stays pretty flat up top ...get a slipper clutch in there now and stop messing around... rob z has done killer things with his...or a textralia my buddy has over 300 6-7k launches on his...single disk feels like stock
Nice to see on a set of 799s...
it should go 134 easy at that weight and power..
what's the goal et?
also the DA was crazy good -1300ft that's awesome...blow some of that my way
what's the goal et?
what's the goal et?
what's the goal et?
DA was about -1000 when I got my limited runs in, the goal is bottom tens, anything beyond that is bonus. The last clutch before this one launched hard, but I could not get it to shift over 7k. This one would not hold the power at all. Im done with single discs, soft lok is $2500 so for now thats out, im going with a twin disc most likely, ~1400.
Thanks Chris,
Yeah, im trying... you still going to atco?
and the clutch was a little over 300 miles...myabe 500 not sure exactly but at least 300.
video:
first pass off the trailer http://www.youtube.com/watch?v=hf1iU78NwLo
Soft roll out later 11.0 @ 130 You can hear it slip going into 3rd, as I ease back into it. also slipped 100 ft before the traps in 4th. http://www.youtube.com/watch?v=tMzk_67ADjY
Thanks, I would try the tex but im pretty sure it will be close to the monster, which held great, but have you tried shifting it @ 7600? This modified ram just would not hold anything... I think Im going with the mcleod street twin, it's a borg and beck long style PP plate and is light @ ~35lbs with the flywheel... Already spent more than the price of a twin disc in clutches that havent worked.....
#33
yes, it seemed fine on the street, did some launches and high rpm shifts, it was fine.... as soon as the slicks gripped the track it was done.
#34
i ran the street twin and at rpm past 7200 it was junk. The tex has worked great at anything over 7k plus. And i put over 300 7 k hits on mine. But i have stepped up to the mcload slipper well see. Plus light fly wheels suck for a stick.
#38
My car **** a twin as well. Started slipping bad. It was the mcloud street twin. Had a tex. and it had the typical problems, didn't wanna pwr shift high PRM. I now have a Monster lv 6 with the chromoly flywheel. Flawless thus far. Been the best driving clutch too. I love it. Never shifted it at 7600 tho....
Good luck man.
Good luck man.
#40
clutches
+ 1 For Monster clutches...I have been thru 3 Ram Hd's...#1 Spit a spring out & jammed inbetween the PP & Flywheel then blew my entire hyd. system.# 2 A free replacement from Ram,# 3 Slipped in 3rd on the $ run at ARM DROP LIVE in Memphis,Tn.I am only shifting at 7000 RPM as well as leaving at 7000RPM So far there have been no issues with the Monster set up. '72 SS Camaro m6 346 h/c set up 430rwh [stock short block] 11.43's @ 119mph on et streets.....Rod Bolts & Custom Pat G. Cam coming this winter.
