Going to the Dyno..Guess my numbers........
Old Nov 14, 2010 | 05:11 PM
RibeiroBJJ's Avatar
Default Going to the Dyno..Guess my numbers........
I will be going to the dyno on Wednesday and am curious what I will put down vs what you guys think...I have to install my efans still as well as gears/stall , and want to see the gain I get from any future mods...
Mod list:
-04 LS1 short block w/ arp rod bolts
-PRC stage 2.5 5.3 heads Un-milled
-Comp 216/218 .525/.532 114 lsa
-Comp 918's, TI retainers, LS7 lifters
-SLP pump/chain
-Scorpion 1.7 rocker arms
-oe head gaskets
-Trick flow UD pulley
-Ported/modded 78 mm t-body
-ASM 1 3/4" x 2 1/2" lt headers
-2 1/2" catted Y pipe to 3" corsa sport
-Volant CAI
-EGR/AIR delete
-Base mailorder Tune from Blackbear (conservative)
-4l60e 2WD Stock Converter 3.42 gears
After I dyno and get a basline I will change things up a bit..I want to get a spec'd cam in the 22x/.56x range as well as 3.90 gears and FAST lsxrt intake manifold with a 92mm throttle body and dyno after each one...let me know what you think it will put down with the small cam...
Old Nov 14, 2010 | 05:16 PM
litle88's Avatar
380?
Goodluck!
Old Nov 14, 2010 | 05:30 PM
RibeiroBJJ's Avatar
Originally Posted by litle88
380?
Goodluck!
Really? I would be happy with that..and 400 with bigger cam and dyno tune..
I forgot to mention I also have a Walbro 255 and 32lb Injectors......
Old Nov 15, 2010 | 11:12 AM
Bill'sWS6's Avatar
369RWHP & 360RWTQ
Have Fun.
Old Nov 15, 2010 | 06:37 PM
SS MPSTR's Avatar
Yup - 370ish rwhp, 360ish rwtq.
Old Nov 15, 2010 | 07:34 PM
RibeiroBJJ's Avatar
Originally Posted by Bill'sWS6
369RWHP & 360RWTQ
Have Fun.
I see your setup is similar...How much did you make with the larger cam and Fast intake...
2 more days... I would definately be happy with above numbers
Old Nov 16, 2010 | 10:37 AM
thunderstruck507's Avatar
I would hope you do better than that with heads/cam even if it's small.
Less than 380 on a locked stock stall and I would be bummed as ****.
Old Nov 17, 2010 | 04:32 PM
Bill'sWS6's Avatar
Here is a video of my pull. This was when the car was having the tune tweaked. I have my heads milled and a some extra port work. I also have bigger injectors.
On a Mustang Dyno my car put down 405RWHP with a 4,000+ UNLOCKED converter flashing to 4,900 rpms. I was pretty happy with it. The biggest surprise was where it made max power at, 7,000 rpms.
http://www.youtube.com/watch?v=oI4NHJgNOP8
Post up your numbers as soon as you can.
Good Luck.
Bill
Old Nov 23, 2010 | 10:36 AM
01 CamaroSS SLP's Avatar
nice numbers!
Old Nov 27, 2010 | 10:16 AM
RibeiroBJJ's Avatar
Thats a clean car Bill! and nice numbers..
Well I did not dyno that wednesday , instead I went yesterday..It was around 50-55* outside ...perfect for the dyno..All pulls were done on a Dyno Dynamics 850...
First pull 387 rwhp 377 rwtq
2nd pull 381 rwhp 375 rwtq
third pull 384 rwhp 376 rwtq
I agree that I could be making more , but with the 78mm stock truck intake and tb and small cam I know there is more to be had..But pulling a new 5.0 from 30-85ish is proof enough for me...the truck runs good..1/8mi track times to follow
-I also sent PatG a PM to see where I could optimize my setup and what he thinks about a new cam
Old Nov 27, 2010 | 10:32 AM
manfred717's Avatar
Good numbers! I would swap the intake manifold as well as that is probably hindering you significantly.
Old Nov 27, 2010 | 02:47 PM
camaro98z28's Avatar
This is my prediction
1st pull 387 rwhp 377 rwtq
3rd pull 384 rwhp 376 rwtq
Old Nov 29, 2010 | 02:22 PM
Bill'sWS6's Avatar
Nice number, now get that thing to the track. Number are number and track times are what counts.
With that intake I am surprised that the numbers were that high. I thought it would restrict you a bit more. Just think what a nice ported 92mm Fast intake and 92mm TB would add
Old Nov 30, 2010 | 08:22 PM
litle88's Avatar
WHAT I SAY
Do I win anything?
Congrats on your setup!
