Using Dyno graph to figure/adjust shift points
Old Dec 17, 2010 | 10:55 AM
Intercooler2's Avatar
Default Using Dyno graph to figure/adjust shift points
With a graph you should be able to figure exactly where to shift for best ET/MPH yes? Okay...
Max/Peak TQ 5250
Max/Peak HP 6500
1-2?
2-3?
Go!
Old Dec 17, 2010 | 12:47 PM
AINT SKEERED's Avatar
I like to go about 300 above peak so it falls into a usable power band.On my Nova, i shift at 7200 even though it peaks at 6500 or so, with the gears im running it keeps it in the power band longer.
My trans am i shift at 6800
Old Dec 17, 2010 | 02:23 PM
1-2 and 2-3 you shift both at 6800? Is that by the factory tach (is it accurate?) or off another means?
My car last track visit was shifting at 6300 when I watched the shifts. I imagine I am losing a decent bit if it is accurate in MPH/ET that extra 500 RPM.
Old Dec 17, 2010 | 02:41 PM
No , I have a harland shift light set at 6800. On my Nova i shift out of first around 7000, and out of second around 7200. this is by a real tach, not the factory junk. I am about 2 mph faster in the nova shifting high then if i shift at 6500. Makes a difference on my car but it has more cam then it needs.
the trans am is the same, it dont like being shifted to low.
Old Dec 18, 2010 | 10:50 AM
Ragtop 99's Avatar
My philosophy is shift for highest average HP.
NA stock cubed manual cars are fairly straight forward. With the wide spacing in of the stock gears, the simple answer is to run most cams as high as your engine is capable of supporting. Dropping below 5000 rpm costs power.
With an auto running an unlocked high stall, the answer is not as simple as the stall does not fall all the way back and some stalls provide extra torque multiplication on the upshift. So you need as a starting point need to know where the rpms drop to when you shift at 300 rpm past peak, 500 rpm past peak and as much as 700 rpm past peak as a starting point. The bigger the stall, typically the less you have to go past peak in order to achieve the highest average power.
Old Dec 20, 2010 | 11:22 PM
Isolde's Avatar
You probably can't rev it high enough to do this, but the proven idea is to shift at whatever rpm will give you the same driveshaft torque after the upshift as you had before the upshift. That results in the best acceleration.
Assuming good lifters, springs, pushrods and rod bolts, you should be holding first to 7200.
Old Dec 20, 2010 | 11:41 PM
Damian's Avatar
LSX Mechanic
If peak is 6500, I would be shiftin @ 6800 in every gear.
Old Dec 21, 2010 | 06:41 AM
That is what i do in my T/A but my nova picks up quite a bit if i shift at 7200.even though it peaks at 6500. it carries out further. Cam is a Cam Motion 239/243 .612 lift 112lsa 110 c.l in a 347 ls1. Likes rpm
Old Dec 21, 2010 | 07:37 AM
I checked it again yesterday and it was shifting 6300-6400 on the factory tach. Anyone know how far off it is?
Old Dec 21, 2010 | 02:06 PM
MikeG's Avatar
It depends on how well the power carries. Some setups peak and the drop off sharply, others carry the power well for another 5-700 RPM. Could you post the graph up?
Old Dec 21, 2010 | 03:16 PM
Frost's Avatar
It's not some standard that you can get from someone else; they are all wrong but they are all a little different. A shiftlight is a must-have for a manual trans car.
Old Dec 21, 2010 | 03:17 PM
Isolde's Avatar
If it drops sharply, it's a parts problem. Typically springs. Second most common culprit is lifters.
Old Dec 23, 2010 | 06:15 PM
Ragtop 99's Avatar
That's exactly why you have to look at the curve.
The old rule of thumb of using 300 rpm came from the days of racers running tight LSA cams (e.g. 106 - 110) that made great midrange and tend to drop off quickly after peak. Higher LSA cams w/o a lot of advance ground in tend to carry very well.
A stock LS3 peaks about 5800 - 5900 rpm. Shift lower than 6500 rpm and MPH drops. Same thing with the LS7. Stock peaks at no more than 6300 but HP is almost flat to 7000. Best MPH comes from running it to redline.
Old Dec 23, 2010 | 08:33 PM
LIL SS's Avatar
Moderator
I think every car and combo is a little different.
I have heard some pick up by short shifting 1-2 300-400 rpm bellow peak to use the verter to multiply TQ and then over rev (past peak) by 300-400rpm on the 2-3 shift.
But some verters that doesn't work with and shifting 300-400 past peak both gears might work better.
Or even 100-200 above peak.
Set your shiftlight at say 6,400 as a starting point. Make 2-3 passes shifting 1-2 and 2-3 there. Then keep the 1-2 shift there but move the 2-3 up a second or so after the light goes off. See if it went faster. If it did, find the sweet spot for the 2-3 keeping the 1-2 at 6,400. Once you found that, Keep the 2-3 at the same rpm but work on the 1-2. Move the light to 6,500 for 2 passes, see what it does. Then 6,600 again for 2 passes. Keep moving it until you find the sweet spot on the 1-2.
Old Dec 24, 2010 | 12:13 AM
Mine carried 450 up to 6800
Old Dec 24, 2010 | 01:37 PM
Ragtop 99's Avatar
If you peaked at 456 but still have 450 at 6800, I'd try 7,000 rpm if your car is up to the task.
Old Dec 24, 2010 | 02:00 PM
Yea it looks like 6500 at peak power and doesn't really move on out until they stopped.
Attached Thumbnails Using Dyno graph to figure/adjust shift points-1.jpg
Old Dec 25, 2010 | 09:02 AM
Ragtop 99's Avatar
definitely looks like there will be good power to at least 7k.
Old Dec 29, 2010 | 09:13 PM
MauriSSio's Avatar
looks like power was dropping. On my dyno sheet it leveled off like that at the end after they let off. Looks like they lifted at 6700rpm. That engine should be spun to 7K though IMO or something close to that.
