SDPC LS3 427 with L92 heads dyno
Old Dec 17, 2010 | 11:17 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Default SDPC LS3 427 with L92 heads dyno
SDPC LS3 427 -4.070" bore -4.100" stroke
SDPC CNC LS3 heads
235/243 .621/.624 113+1
FAST 102mm intake
NW 102mm TB
The customer not only wanted bigger cubes and great power, but he wanted to drive the car every day and also for the engine to show up ready to drop in. We completed the longblock with a FAST 102 intake, Nick Williams TB, valve covers, coils, injectors, and everything necessary to simply drop the engine in and run. Here are pics of what he received (his pictures) and the dyno sheet.
Customer had the engine installed local to him and it was tuned by Vengeance Racing. (Thanks Ron!)
Over 500rwhp through an A4 with 3200 converter
508rwhp, 480rwtq
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Dec 17, 2010 | 01:04 PM
1nastyss's Avatar
Thats strong number through an auto, should be a quick car
Old Dec 17, 2010 | 01:10 PM
offaxis's Avatar
Simular numbers to my 418. Im sure he will be very happy with the results.
Old Dec 17, 2010 | 04:28 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Do ya'll not have problems with longevity running a 4.1 stroke?
Old Dec 17, 2010 | 04:39 PM
We do not. We have done countless shortblocks on our "El Toro" program with our LS2 413 and LS3 427, and many other vendors do them regularly as well. Properly built there should not be any problems at all, we have great luck with them. They were somewhat problematic years back when the pistons for them were new, but for several years now the piston designs have been revised to an extent that there is no problem running a 4.100" stroke.
__________________
Old Dec 17, 2010 | 05:07 PM
1slow01Z71's Avatar
Glad to see the technology has advanced. I believe a lot of that was on my shoulders back in the day(05-06) after both JE and Wiseco failed to make a piston that wouldnt drink oil after 200 miles. Of course I was running an iron block so the short cylinders only made the problem worse.
Not bad power, I bet with a decent stall speed that thing is going to be a ton of fun on the street.
Old Dec 17, 2010 | 07:23 PM
RJB01camaross's Avatar
Solid numbers!!!
Old Dec 18, 2010 | 12:02 AM
litle88's Avatar
I have a 416 short blocks that you guys built #2765 it is still new, and I would like to know if this motor might be the "problematic" ones with the outdated pistons? They have a -2 cc valve relief.
Old Dec 18, 2010 | 12:08 AM
litle88's Avatar
Can I have some info on your build? Like compression, cam and intake your using?
Thanks
Old Dec 18, 2010 | 12:56 AM
Originally Posted by litle88
I have a 416 short blocks that you guys built #2765 it is still new, and I would like to know if this motor might be the "problematic" ones with the outdated pistons? They have a -2 cc valve relief. I have concidered maybe sending it to you guys just to dbl check everything and making sure it's ok according to your specs. How much would something like this cost?
The 416 is a 4.00" stroke setup, so it is totally fine regardless of age no worries whatsoever
__________________
Old Dec 18, 2010 | 11:16 AM
jcoker's Avatar
Nice #'s. I've had an El Toro block in my car for three years with no problems.
Old Dec 18, 2010 | 11:17 AM
litle88's Avatar
What are you putting down?
What's your set up?
Old Dec 18, 2010 | 06:09 PM
STAR's Avatar
Great results! Do you know if the converter was locked?
Old Dec 18, 2010 | 06:50 PM
Glad to hear it We have have incredible success with these shortblocks
The owner informed us that it was unlocked.
__________________
Old Dec 18, 2010 | 09:22 PM
chriswtx's Avatar
What internals on these motors?
Old Dec 19, 2010 | 02:11 AM
Detoxx03's Avatar
Very nice setup there. Can't wait until I do my new setup.
Old Dec 19, 2010 | 05:32 AM
MYSTIC-1SC's Avatar
Looks to be a strong setup.
Old Dec 19, 2010 | 08:39 AM
offaxis's Avatar
Thats weird cause it sure looks alot like a locked converter to me.
Im not the locked vs unlocked converter police though so...
Im sure the customer will be happy either way.
Old Dec 19, 2010 | 08:45 AM
2000ws6transam's Avatar
nice numbers man congratz
Old Dec 19, 2010 | 10:51 AM
We can use any variety of internals to meet a customer's needs and budget. For cranks we stock Scat, Callies, and Manley. For rods we stock scat and Callies both in h-beam and i-beam. We use Manley pistons standard, but also use JE, Diamond, Wiseco, and Mahle when called for. The El Toro line uses Callies Compstar crank and rods standard, and we have a budget line that uses Scat crank and rods. Both use the Manley pistons standard, but we have been using the Mahle more often and have had great luck with those as well. This setup is using the Mahle 4.070 powerpack.
__________________
