hp guess on my new build? opinions welcomed!
Im in the middle of my new build and just wanting some opinion on my new build and thoughts of what kind of power it will make. I got all the parts just got to put everything together. The consist of stock LS1 ci, Scat H-beam rods, Mahle Pistons -4cc, double roller timing, ported oil pump, MS4 camshaft, Underdrive pulley, PRC 2.5 243 Heads milled to 59cc, 7.350 pushrods, LS6 intake, Pacesetter Longtube headers, x-pipe, true dual w/ corsa mufflers, tci 3800 stall, 42lb injectors. The plans are to get the motor to run as best as I can get it to run then I am going to run a 2 stage nitrous setup 250hp total. let me know what you think about the numbers it could produce on motor and on nitrous, plus what kind of times it might be able to run (4.10 gears), and also trying to decide if I should go ahead and spend the money for a FAST setup. Thanks
400? You nuts? Cam only MS4 cars do that!
MS3/TSP 5.3 2.5 car through a 9":https://ls1tech.com/forums/dynamomet...ph-inside.html
With a FAST it should be well over 430 even through an Auto or something is wrong.
