anyone have a comparing dyno 383 stroker
Only thing that confuses me is that i was reading threw some threads and patrick g compared/said that a 236-242 cam in a 383, is similar to a 230-236 in a 346...going off this.....
so if mines a lil bucky at 232-234 in a 346, by math sense = a 238-242 in a 383....
so if im trying to minimize the buck, i`d want something that equals like a 230-232 in a 346, so in a 383 it`d be a 236-238........but yours is fine with no street problems....
I`m obviously not understanding everything right.....Will someone chime in to help me better understand.....
I'll also run a fast 102 with trickflow heads and hope for 500rwhp.
Seems like thats just about the same in drivability , maybe even a little better....
And to answer a previous question, i will be N/A im sure with nitrous....
anyone else have more examples on comparing 346-383 cams and how they act.....
But whatever...Back on topic. "anyone know if a 232-234 be to small for a 383? its in my 346 ls6 and its almost perfect in driveablity to me. bucks a lil if not engaged right but overall ok, i think a 230-232 would have been a better choice for me just to take that lil annoyance away . Can someone compare what cam i`d like in 383?"
Also, i still want to be able to rev it up top and not loose any power, around 6800-7000rpm.
Heres exactly what i want. A 383ci n/a with a 200shot occasionally. making power throughout the powerband, but mostly mid to high. I want a smoother idle this time`mines currently a 112+0`....so im thinking at Least a 114 this time....
Was hoping it would do a bit better but it's a safe/reliable tune AFR 13.0 with 26*max timing and no KR.
your idling and driving issues are TUNE related and have 0 to do with your baby 232/234 cam. that cam should not buck or surge at all, and definitely should not cause your car to die, ever, under most any circumstance. that engine is tuned very poorly. i have personally driven 2 cars, both of which had more than 20* overlap cams, in stock ls1 engines, neither of which died, nor did they surge or hunt for an idle when coming to a stop. they were honestly very easy to drive, despite their size.
good tuning > *.
edit: local guy here has a carbed 383 that put down low 430s on the dyno, through a th400, 9" and slicks. the car went high 9s @ 134+ last year. i believe he was using a trex cam and some out of the box afr heads. he has done some work over the winter that should lead to even quicker/faster times.
Thats disappointing to hear that Nick seems to not tune well even though alot of people said he`s good. It`s just frustrating to know i drive far out of my way not once, but twice and spent alot on him to know this.....wtf...i guess new tuner is in my future unless he response on here and settles this....
your first clue to that guy's tuning ability should've laid with your dyno numbers. bolt on ls6 motors typically make 390whp...a cammed ls6 only making 409...? maybe on stock manifolds. usually 230+ duration cammed ls6 cars will easily make 420+. it seems like i've seen hundreds of lg cammed zo6 cars making 425+ with just headers and a tune.
is your car an auto or stick?
I keep reading and reading on what people say on what 383`s like a respond to well, and it seems like that would be a nice set up....
Anyone with high cam info can help? i have prc ls6 2.5 heads and basic bolt ons... Any advice on those heads and mods, and match my street/strip drivability?
