Trickflow 220s and G5X4 cam???
Old Jan 31, 2011 | 04:57 PM
litle88's Avatar
^^^^I know someone who is dreaming too not pointing fIngers^^^^^^^^^^^^^
Old Jan 31, 2011 | 09:09 PM
98blueSScamaro's Avatar
there is no dreaming here. i know what my numbers will be. And i know my car will still hold the tilte .
Old Jan 31, 2011 | 10:16 PM
Orange Juice's Avatar
Originally Posted by 30th t/a
All I can say is that I made 464/414 with the G5X4, AFR 205s & Kooks Lts with a 6 speed.
Which is only a tad better than when I made 455/410 with the G5X3, old Absolute Speed 2.5's & a budget set of Pacesetter Lts. With the bigger cam, better heads & better LTs i expected more than a 9 rwhp gain.
Yea I wish that I had never sold my AS heads,
Could have put together a nice little stroker with those heads.
Old Feb 2, 2011 | 12:40 PM
ripinLS1's Avatar
I ran these heads( TFS 220 AS CAST) ls1 stock bottem end with 96,000.MS4 cam FAST 102/102 intake TB. 6SPEED . car ran a 11.32 @ 122MPH 1.6 60FT. Full weight car 4.11 gears.The car put down 463 RWHP 413 RWTQ.
Old Feb 2, 2011 | 11:04 PM
i put that down 455hhp and 405tq with stock ls6 heads and a vindicator with a 90/90 setup.
I my car only made 463 and 413 i would be seeing were i could get more out of it. because 220 trick flows and a ms4 with a 102 should my some good power at least 47x almost 48x. with a m6
Old Feb 3, 2011 | 01:50 PM
reeperz28's Avatar
What did your car run in the quarter?? His was a full weight car plus no single one dyno is the same. Plus comparing other supporting mods are important as well .
Old Feb 3, 2011 | 06:30 PM
my car runs in the 10.8X spot and Way less mod And i heavy At 3500lbs but like you said i Nailed the supporting mods.
Old Feb 3, 2011 | 07:39 PM
ripinLS1's Avatar
Default 220 heads
Thats bads ***. Iam doing a SDPC LS2 413 build right now.plus your 60 ft was a 1.4 mine was a 1.6
Old Feb 4, 2011 | 09:10 PM
chrs1313's Avatar
don't look at ET so much compare mph if both cars have the same trans...that is how much hp/weight you are putting to the ground...
Old Feb 4, 2011 | 09:13 PM
chrs1313's Avatar
bahaha well played Sir
...but I think someone else is gonna be mad when a big ole built coated engine gets pulled by gm factory junk...
when is that victor jr and razor elbow going on...hehe
Old Feb 4, 2011 | 10:05 PM
Squirts11's Avatar
While you're spending good money on this big head/cam combo, you're leaving a good amount of hp on the table (all throughout the powerband) by sticking with the ls6 intake. Honestly, I know it all comes down to budget, but you really should hold off on the build/tune until you can pick up a FAST/Vic Jr intake.
You'll make solid numbers regardless, but if you think you'll eventually upgrade from the ls6 intake, it would be ideal to save and do it all conjunctively.
Old Feb 5, 2011 | 10:49 AM
  #32
Dont make me whip out hte credit card haha
Old Feb 5, 2011 | 11:35 AM
  #33
chrs1313's Avatar
my middle name is VISA...haha
when you picking up the ride?
Old Feb 5, 2011 | 11:47 AM
  #34
Not anytime soontill the roads clean up alittle bit more atleast
Old Feb 22, 2011 | 07:18 PM
  #35
jzingre's Avatar
Originally Posted by mike m
I am going to be switching out my ls6 heads to a set of Trickflow 220s with a stage 1 port job from TEA milled to 59cc. Has anyone on here run a set of these with the G5X4 cam ? My car made just over 400 with unmilled stock ls6 heads. I'm expecting some major improvement with the TF 220's.
This is going into a 01 camaro stock cubes with a PT4400 convert through 3.73 gears. I'm gonna port my LS6 intake until I buy either a LS2 intake or a fast. car has full bolt ons, ported TB and full drag suspension.
Check out my setup. I'm running trick flow as cast 220's with Tea porting done to them. I had them flowed by tea and they are right at 215cnc levels. Milled to 57.5cc's, 11.5.1cr, and a polluter cam...I think it is almost identical to a g5x4. I put down 463/399 through a dana 60 and junk bbk85/85.
https://ls1tech.com/forums/dynamomet...h-c-i-ls1.html
Old Feb 27, 2011 | 10:35 AM
  #36
redsap05's Avatar
Trick flow heads really respond well to LSL or XFI lobes. Since you went to 59cc you shoud look at comps 231/239 Lsr series cam (LSL lobes) should clear and make killer power. For what its worth the ed curtis cam's seem to agree with trick flow heads reall well too, theres a member here with a streetsweeper ht (228/232 111lsa) and tfs 225's making over 490rwhp and 453rwtrq. I would like to see one of ed's tigershark 232/236 cams with trickflows. A tigershark and Advanced induction 243's did 504rwhp and trapped 100mph in the 1/8th mile . Remember with trick flow heads its not so much about the size of the cam. Since the heads flow killer at mid lift you want a lobe profie that takes advantage of that.
Old Feb 28, 2011 | 09:25 PM
  #37
firefighter813x's Avatar
Does absolute speed have a website?
Old Apr 8, 2011 | 06:00 PM
  #38
Mat's Avatar
Mat
Nope, they're done and gone. Too bad too. Great company and awesome reviews on the head work they put out.
I've got a set right now that I can't wait to install. Sorry Orange Juice, I'm excited about seeing how they work though!
Old Apr 8, 2011 | 07:01 PM
  #39
06X6spdGTO's Avatar
made 460rwhp 418rwtq with a set of home ported LS6's on my C5z with a SCR of 10.6-10.7:1. The rest of the mods are in sig
Old Apr 8, 2011 | 07:05 PM
  #40
bayer-z28's Avatar
Don't mean to jack but who's cams are these in question? Vrx5 and G5X4?? Vrx5 = Vengeance Racing?
