Thunder Racing TRx v.2 cam/stock heads - 451rwhp/408rwtq!
Old 02-20-2004, 08:48 PM
  #121
SMOKIN01TA's Avatar
Originally Posted by wannabels1
Old 02-20-2004, 09:23 PM
  #122
AINT SKEERED's Avatar
Hey Rodney, you going to Hattiesburg on the 29th?
Old 02-20-2004, 10:22 PM
  #123
SMOKIN01TA's Avatar
if the cam is in and tuned by then i might.
Old 02-21-2004, 10:07 PM
  #124
BoneSS's Avatar
Any word on what heads cam be used with this cam okay?
Old 02-21-2004, 10:15 PM
  #125
SMOKIN01TA's Avatar
cam was designed to max out the stock head clearance, so any unmilled heads that retain stock height should work. if its not stock heads or deck has been resurfaced i would check it. thats just my opinion.
Old 02-21-2004, 10:32 PM
  #126
SSactionLs1's Avatar
so....theres gonna be V1?
Old 02-23-2004, 01:57 PM
  #127
CHRISPY's Avatar
Still waiting for the graph (LS6 overlay)
Old 02-23-2004, 02:04 PM
  #128
SMOKIN01TA's Avatar
call thunder and ask jason or geoff. ill try and finout when i go by tonight.
Old 02-23-2004, 02:14 PM
  #129
Restricted User
2001 Pewter WS6's Avatar
When is the cam going to be ready to ship???
Old 02-23-2004, 03:30 PM
  #130
SMOKIN01TA's Avatar
got mine last week. but no shiping involved in that
Old 02-23-2004, 10:54 PM
  #131
wannabels1's Avatar
Originally Posted by SMOKIN01TA
currently installing the new 243/248 thunder cam..
for someone who claims to know all about thunder racing and their cams, could you at least get the specs right?
Old 02-23-2004, 11:04 PM
  #132
SMOKIN01TA's Avatar
hey guess what dumb ***, the cam doctor sheet on my cam says. 242.9/248.2
with jasons signature on it so now who feels stupid.
you realize you first 7 posts all you have done is make youself look like a fool
Old 02-23-2004, 11:08 PM
  #133
wannabels1's Avatar
i dont feel stupid....... 242.9 doesnt equal 243 now does it?
Old 02-23-2004, 11:13 PM
  #134
SMOKIN01TA's Avatar
i think its about time to stop the back and forth stuff and call a truce. its gettin old.
btw, when you laughed because i guess the differnce between v.1 and v.2 wrong. i really wasnt wrong. read jasons other post in the other trex thread. he said the intake was the same and the exhaust was smaller, which was exactly what i had said. just though id clear that up for old time sake.
Old 02-25-2004, 11:33 AM
  #135
35th SS's Avatar
man you too are funny.btw stock minor porting on heads milled@0.003 would it be okay for this cam?thanks.
Old 02-25-2004, 01:25 PM
  #136
94-98 Trans Am's Avatar
Lightbulb
Originally Posted by SouthFL.02.SS
Yeah, what kind of upgraded heads (over LS1 stockers) can be combined safely with this cam so as to meet proper P/V clearance?
I would say any head that hasn't been shaved/milled on the bottom (which makes it closer to the block...in turn moves valves closer the block when they move down to open and close) therefore raising compression. LS6 heads have slightly higher compression but its not due to milling its due to the combustion chamber size which has no major effect on PTV. Any head that is higher compression than stock that isn't milled will be fine (such as patriot performance heads will work fine, because they weld combustion chambers smaller)
-Corey
Old 02-25-2004, 03:43 PM
  #137
Tim 98z's Avatar
I would not say any aftermarket head that is unmilled. You have to think about larger valves also. I would check PTV with any aftermarket head. Just my .02
Old 02-25-2004, 07:13 PM
  #138
35th SS's Avatar
going with this cam on the faked SS.just dont want to be the first one yet.thanks.Rex
Old 02-25-2004, 07:58 PM
  #139
sununix69's Avatar
I want to see track times :-) If it makes 450 peak RWHP and runs a low 12's high 11's well?? hehe but if this ends up running low 11's or high 10's then worth every penny.
Old 02-25-2004, 08:00 PM
  #140
SMOKIN01TA's Avatar
considering im already at the bottom of the 12's with nittos, i dont think you have to worry about it running that. with my new gears/tires and weight reduction im hoping to break 10's
Quick Reply: Thunder Racing TRx v.2 cam/stock heads - 451rwhp/408rwtq!
