810rwhp 565rwtq Naturally Aspirated
just a quick run down. we dyno'd the car today and put down what i thought were really good numbers. the converter was flashing to 7300rpm.
we were pulling it to 8800rpm
it is a:
468ci Lsx tall deck block
Mozez Canted valve heads
60mm Cam
Jesel .937 Keyway lifters
Manton 9/16 pushrods
Jesel Solid Body Shaft System
Titanium valves.
Psi springs
Full dry sump system
Beck Sheetmetal intake with 2 dominator TB's
rossler th400
7000 stall
4.56 gears
9" rear end
and slicks.
i think all went well.
im going to be going to the track friday if it doest rain and im hoping to run some 5.40's or 5.30's
it is a:
60mm Cam
Titanium valves.
Psi springs
rossler th400
7000 stall
4.56 gears
9" rear end
and slicks.
wow this looks super similar to the cover of the hot rod magazine i have about LS conversions/LS in general. the first guy had a 468 in a WS6 and it made like 938hp on the engine dyno. very similar. your car sounds like its badass sir.
