dynoed the 383 UPDATED track results 4/16
Old 03-23-2011, 10:23 AM
thunderstruck507's Avatar
Originally Posted by 09camaro383
No is not a 400 is a built 4l60e i think both auto trans should eat about the same?? About 25-35hp?
Loss is always an estimated percentage, not a set number. For example, a higher powered car might lose 40hp where a lower power car could lose 20hp.
Old 03-23-2011, 02:31 PM
2002silverz28matt's Avatar
Those numbers seem about right considering the drivetrain loss. I am runnin a 383 11.8 cr fast 102 ported tfs 225cc 242/250 cam th400 5200 stall strange s60 and I dynoed low 400's as well
Old 03-23-2011, 04:57 PM
09camaro383's Avatar
i know that and i was only referring to my setup and his
Old 04-05-2011, 10:10 AM
ls1curt's Avatar
got a video of it up.
http://www.youtube.com/watch?v=SS2H8GC3Qg0
Old 04-05-2011, 12:39 PM
1989GTA's Avatar
IMHO that dynometer and your Yank 4500 stall are not compatible. There is no way your torque numbers should still be climbing after 5250 rpm. You might want to consider re-installing your old factory torque converter to tune with.
Old 04-10-2011, 05:23 PM
SS1875's Avatar
Just ran my 383 after a Frost tune on a Dynojet. Put down 471 RWHP/ 441 RWTQ.
All be it through an M6 and a MWC 9".
Old 04-10-2011, 05:56 PM
s346k's Avatar
oh wow that's easily a low 10 car. dynos are gay. a big stall th400 on a 12b and slicks will be breakin hearts with that dynosheet taped in the rear window.
Old 04-10-2011, 05:58 PM
2002_z28_m6's Avatar
Remember the car has a th400 in it with a 4500 stall. Its not going to be a dyno queen but should run some solid numbers at the track. The dyno is a tuning tool to get the car tuned and let it rip at the track. Dyno's can be made to say anything but track numbers dont lie. This car should run some solid numbers.
Old 04-11-2011, 02:06 AM
Ls_Nova's Avatar
any track updates????
Old 04-11-2011, 06:39 AM
ls1curt's Avatar
going to the track this saturday, will keep you guys updated
Old 04-11-2011, 09:52 AM
SS1875's Avatar
Good luck...I hope it goes well for you.
Old 04-11-2011, 10:00 AM
  #32
SS1875's Avatar
Yeah, I can read!! My post was to simply put down some comparison numbers for the naysayer's out there not to emply anything else. As usual someone has to make a comment.
The car should/will run strong and be fun to drive...no doubt about it.
Old 04-11-2011, 03:29 PM
  #33
02SOMWS6's Avatar
if the stock rockers don't fix the problem you might want to try a set of hollow stem LS3 intake valves . You can have them turned down as small as a 2.04 by TEA
Old 04-16-2011, 03:44 PM
  #34
ls1curt's Avatar
went to the track today. first pass was a 10.7@128 and the best of the day was a 10.46@129. car has more in it, but i was very happy with the times it put out.
this was n/a
Old 04-16-2011, 04:13 PM
  #35
30th t/a's Avatar
Congrats! Whats the race weight and what was the DA of the track?
Old 04-16-2011, 04:22 PM
  #36
ls1curt's Avatar
raceweight was 3450 and the d/a was around 850
Old 04-16-2011, 04:25 PM
  #37
djfury05's Avatar
hot damn! No spray yet? Tires, 60ft, 1/8th mph and e.t etc.. quit skimpin' the ole info lol
edit* I can kind of see the slip.. 102.88 mph 6.64 1/8th et? GREAT 60ft if I'm reading 1.324 correctly
Old 04-16-2011, 04:29 PM
  #38
ls1curt's Avatar
time slip is up....hoosier 28x10.5's, full rear suspension and just qa1's in the front
Old 04-16-2011, 04:32 PM
  #39
djfury05's Avatar
15x10 rim?
Old 04-16-2011, 04:33 PM
  #40
ls1curt's Avatar
Originally Posted by djfury05
15x10 rim?
yup..
Quick Reply: dynoed the 383 UPDATED track results 4/16
