new 383
Old Mar 22, 2011 | 08:32 PM
bracketracer's Avatar
Default new 383
Ok, after almost a year of collecting parts to build a new engine for my completely stock 01 Trans Am, I finally saw the fruits of my labor today. I put together a 383 LS6 stroker with LS6 heads (2.5 port), Fast 90/90 (intake ported and matched), 234/239 598/605 114 +1 cam, QTP headers and Kooks true duals (worked like a charm with the QTPs with minimal mods). Started it last night and took it to get tuned today. On a Mustang dyno, the 1st pull was 442, second was 453 with more timing, and the third was 485 with more timing. I was pleased since he had the exact same combo in a vette earlier in the week that came in at 420.
The Kooks exhaust sounds awesome although they are a bit loud for my taste. I might add some cats or resonators at some point but it looks great and apparently performs based on the numbers. I took the car for a spin after the tune and it has some serious get you sideways in a hurry power. I like it. :-)
Old Mar 22, 2011 | 08:35 PM
msydow's Avatar
i love my 383. whats the rest of your combo? rear gear and trans?
Old Mar 22, 2011 | 08:45 PM
It has stock 342 gears and M6. No power adders. The engine really comes on strong at 4500.
Old Mar 22, 2011 | 08:48 PM
msydow's Avatar
oh yeah. get a set of gears in it.....totally different animal. if i did it all over again i would probably go with 3.9x's rear gears. already turning 121mph with junk sumitumo's. oh well though. nice numbers. any vids of the kooks exhaust?
Old Mar 22, 2011 | 10:52 PM
Transam1's Avatar
What's compression you at?
Old Mar 22, 2011 | 11:07 PM
SS1875's Avatar
What kind of timing are you running??
Old Mar 23, 2011 | 05:14 AM
It has 10.4 compression and running 25 degrees.
Old Apr 10, 2011 | 05:16 PM
SS1875's Avatar
I just put down 471 RWHP/ 441 RWTQ on a dyno jet, 10.99-1 compression, 26* max timing.
Many similar mods to yours.
Old Apr 11, 2011 | 08:48 AM
00 black ss's Avatar
my compression is right around there to. i have stock 243s and a fast 90/90, 1 7/8 lts but my cam is ginormous. 240/256 .647/.647 111lsa eps lobes. im hoping to be putting down similar numbers
Old Apr 11, 2011 | 09:32 AM
SSdreamz's Avatar
471/467 with my 383 AFR 205 heads, LS6 intake, stock TB, 238/240 cam through a 10 bolt. plan on losing some through a new 9 inch, but also look to bring the numbers back up with a 90/90 combo. enjoy the car
Old Apr 11, 2011 | 09:41 AM
SS1875's Avatar
How doyou like the wavetrac vs. the truetrac?
Old Apr 11, 2011 | 04:07 PM
djfury05's Avatar
where'd u guys get the stroker kits from and how much $? How much $ for labor etc?
Old Apr 11, 2011 | 05:07 PM
SS1875's Avatar
pm sent
Old Apr 11, 2011 | 05:51 PM
RJB01camaross's Avatar
Nice numbers on a mustang dyno!
Old Apr 11, 2011 | 06:48 PM
ChucksZ06's Avatar
Good job on the build...It shows if you put together a good combo of parts with attention to detail you can make great power without spending fortune on exotic parts.
Old Apr 14, 2011 | 10:29 AM
never had the true trac. put probably around 300 miles on my 9 inch n wavetrack. no complaints. rides like stock and with the 4.30s the thing is a beast
Old Apr 16, 2011 | 11:27 PM
SS1875's Avatar
Your car should be really fun to drive with matchinq HP/TQ numbers.
Old Apr 18, 2011 | 10:09 AM
Fbodyjunkie06's Avatar
And this is why I think the 383 fwiw is the ultimate budget/STREET/strip motor. With a cam that is in the high 230's low 240's duration and .610-.630 lift with a good set of aftermarket heads or cnc'd 243's you can make almost 500rwhp or 500rwhp with 470+rwtq. Now that my friends makes for one fun ride that will idle, cruise with the a/c on and then go run a 10.x 1/4 time after bolting the D/R's on and then drive back home with the a/c and tunes on.
Old Apr 18, 2011 | 08:58 PM
SS1875's Avatar
Very true. I do wish that my cam was a bit bigger and more aggressive. Driveability was a concern @ the time and unfortunately now it is money. Down the road I may decide to change the cam and get some better heads to obtain my goal of 500/480 N/A.
For now the Nitrous is being readied and should make it more of an animal than it already is.
Old Apr 19, 2011 | 09:48 AM
bjschubert's Avatar
Stroked 383 here, trickflow 215's Kooks 1 7/8's Fast 102 with 96mm TB, and a tiny baby cam because I have a stock converter with an RPM level 5! I put down 453 and 456 on a dynojet. I ran a 12.08 on street tires with a 1.9 60' spinning most of the way. I also balloned the converter and broke the flexplate, Car is currently at vengeance doing a 6 speed conversion and putting at least a VRX5 cam in now!!
