LQ4 bottom end with 5.3 heads dyno numbers and set-ups...
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I have been trying to find dyno numbers for set-ups with an LQ4 bottom end and 5.3 heads that run on 91 octane pump gas. If you guys have your dyno numbers/sheets, and what compression/head gasket your running that would be awesome! The cam information would help a great deal TOO since mine would be going into a truck.
I am looking into getting an LQ4 bottom end for my truck that has a 5.3 in it already, and getting my stock 706 heads ported (or just using them as cores), with a 216/ 224 .585 /.585 on a 115 LSA cam.....
I wanted to see what the pump gas set-ups are like. I have searched and found a few set-ups, but the computer I am using keeps locking up along with the internet going out so I apologize if there are a TON of them that I haven't found.....I am deployed right now so net use is limited for me....thanks for the info in advance!
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
