new results from my GTO
LQ9 short block with pistons cut .060 on both valves
243's with a vj and bowl work only (stock runners)
230/242 .631 .622 on 110lsa (spec'd for a single plane intake)
1 3/4 lts
udp
ls6 intake with a ported tb
the car made 435/421. the changes this winter were a fast 92 with a ptm 92 tb and a svede intake. first pull with no tuning it made 452/407
. the final pull was 465/434 with the injector maxed out. the graph is attached. i've been told i'm leaving power on the table by not switching the cam out for a long runner friendly grind. i picked up a 236/240 (streetsweeper) but i'm not sure if it's worth the swap. any opinions? This is the same build i plan on doing to my Silverado SS. Exciting to see this post and your previous build thread ( been searching Lq9+worked 243's)
This has convinced me to pick up some 243's and send them off to flowtech induction and have them spec a cam out and a Fast 102 lsxrt.
i think after the injectors and some small tweaks it will go 475rwhp. this is also through an ls7 clutch. still not sure if i'm gonna change the cam yet. since i already have it i probably will just to see. thanks for the comment, i pretty happy being they are stock runner 243's that's why i'm unsure. the gto is a heavy brick for sure and i don't want to lose any down low because it is a street car
1 3/4 lts
udp
. the final pull was 465/434 with the injector maxed out. the graph is attached. i've been told i'm leaving power on the table by not switching the cam out for a long runner friendly grind. i picked up a 236/240 (streetsweeper) but i'm not sure if it's worth the swap. any opinions?thanks.
