98 vette with 226/231 cam only dyno result...
Finally, worked out my tuning issues last friday and got the car on the dyno. It put down 387 rwhp and 357 rwtq. Mods are comp cam 226/231, 7.4 hardened pushrods, ls6 oil pump, Ls2 timing chain, dual valve springs, Lt headers, powerbond UD pulley, fast intake, vararam, catted x-pipe, and b&b bullet exhaust. So far I am pretty happy with the results as I am still using the stock 806 heads.
LSX Mechanic
#1 - The #'s are fairly low. Especially for a FAST manifold.
#2 - The heads aren't "holding you back". 806 castings are 5-8cfm at best down, against the newer LS1 castings. 5-8cfm isn't going to hold back 20-30HP. That's an internet myth.
The HP isn't terrible for running through cats, but the TQ should be much higher with a decent size camshaft like that.
LSX Mechanic
I squashed this internet myth many many years ago when I swapped 241's on my 98. I gained absolutely zero power, and the car ran the exact same at the track.
806's aren't a desirable head due to the crappy valve covers and coil mounting situation, but when it comes to stock vs. stock cfm there isn't enough difference to claim a 10-15hp difference. That would be like going from a set of 241's to 243's. The difference in 806/241 is NOT that vast.
5-8hp at best, and that's a stretch.
How much power would be lost with too short a pushrod?
My cam is a Comp grind .576/.563 lift IIRC and I was told to just order the 7.4 pushrods so I did. Wondering if I should measure...but then again I'm likely going to need something different when I put the milled 799 heads on so maybe mine will work.
I need to order a pushrod tool. But just curious, because my car also has low TQ for the mods and IMO low power/trap speed.
I'll say that those numbers doesnt look bad to me; I'm only at 405rwhp, with CNC ported 243s and bigger valves+ported FAST intake, which suck for those mods(smaller cam TR22x). But you know what? it always depends on the dyno. I run way faster than many high dynoing cars(at the track and street too). So dyno are a tuning tool afterall.
Your torque seems a bit low though.
And I see that your FAST is a 78mm too..
