EPS 226/230, tea 5.3 1.5, fast 92/92
I absolutely love your setup and I understand your initial reaction to the numbers.
I went in a very similar direction with my build and when I first heard the numbers I was a bit disappointed. Then I drove the car home and quickly changed my mind. It's nice to make power all throughout the curve in a package with good street manners!
You did a great job assembling a very complimentary setup. I think you'll be pleased with the track performance!
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Your torque curve is identical to mine until 5000 rpm. I really believe you have a valvetrain issue or a restriction in your setup. Your torque drops hard after 5000 rpm and you should be around 445-450 rwhp based on the math of torque and rpm if it didn't drop hard. Did you measure your push rod length? I use 7.350" rods with .020" milled heads. I also used the same headers and exhaust setup as you, except I had a 3.5" cutout.
It's a great setup and when you figure out whats going on it will make quite a bit more power. Did you look at the KPA drop as you went up in RPM? I'm not hating or bashing at all, I know there is more left in it. Here is my graph for example, and like I said almost identical torque curve until 5000 rpm.
![](http://i60.photobucket.com/albums/h8/nitroused383/th_104_0256.jpg)
No worries Nitroused383. I tried and tried to measure pushrod length and came up with 7.350. My heads have been milled about .025. It was super noisey, I mean really bad and I talked to Geoff at EPS about it. He reccomends 7.425 pushrods with that cam on a stock engine. Since I had about .025 milled off I went with 7.4's. I'm not saying that's right that's just what I did.
I appreciate the input. If something's not right I'd love to find what it is.
#32
I think OP has one of best HP/TQ under the curve I've seen in a long time in a stock CI LS1. Very nice combo, congrats.
...Nitroused383, we see you all over the dyno threads with your 444rwhp with the BRE224. Your setup is nice and your numbers too, but you gotta remember that dyno are tuning tools and they are not all the same. I just wanna make a refresh for you on that. FYI, my car has almost the same duration(TR22x), unfriendly 3:42 gear, and my car did trap 117mph in the 1/4 with the same raceweight as you(no spinning,HUGE gear lag). Funny thing, it is with a crappy 2.2 60 feet, and I'm down 40rwhp/30rwtq on you. Not hating, not jealous, I read your thread and you know your ****, but you gotta get over dyno numbers sometimes.
https://ls1tech.com/forums/dynamomet...ts-4-16-a.html
Even me, I was thinking his car was down on power. Hes running 10.46@129mph... with 427rwhp... might be apple to orange because hes got a heavy drivetrain/auto, but still 20rwhp less than you and running wayyyyyyy faster than you, and me of course
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#33
I say your results are right where they should be... that's going to be a fun setup for sure. Don't forget that you are running a 226/230 afterall... that's great power without sacrificing a smooth idle. Geoff told me the same thing, 7.425" with stock heads, 7.400" if you are milling 0.025 or running LS7 lifters... which makes me wonder if you are running LS7 lifters? that would put your pushrods at too short....
I just started up my EPS 230/238 112+2 LSA cam 2 nights ago with stage TSP 2.5 5.3L heads. I am very excited to see that EPS cams make good power through 5.3L heads I was a bit weary of straying away from 243 casting heads. I'll have my results up soon...
#40
Even me, I was thinking his car was down on power. Hes running 10.46@129mph... with 427rwhp... might be apple to orange because hes got a heavy drivetrain/auto, but still 20rwhp less than you and running wayyyyyyy faster than you, and me of course![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
No doubt you ran 117 mph but what was the density altitude you ran at? Based on the correction factors on drag times website for 0 DA' I could trap around 122-124 mph. Now I know alot of tracks back east see up to -1500 DA where people run their best. It's no secret what cool air and sea level tracks can do for an N/A motor. 125 + mph would not be out of the question for 3700lb raceweight.
Sorry to pollute your thread Jay. I had to bring all the facts to the table when someone wants to try and make a comparison. Oh and I'm not even going to argue about stalled auto dyno numbers and track times.
