tsp 228r & patriot 5.3s a4 results!!!
That stock intake & over worked injectors is hurting ya. I dont care what was stated above about the stock intake but it will NOT pull well past 5k RPM's with a aftermarket cam & heads. I drove mine the past 60k miles with a stock intake & just recently swapped in a LS6. Made a huge difference in the way the car is pulling now in the upper RPM's.
Also double check your fuel pressure at the rails, if you have a decent amount of mileage & stock pump go order a Racetronix direct fit pump for $150. As long as your voltage checks out at the plugs for the pump you'll be fine without the hot wire harness if money is tight. I also just did this mod & can tell a difference now that the car is getting enough fuel. I'n not sure where my injectors are at yet as I'm still untuned but I will know in the next few weeks once it hits the rollers if I'm maxed as well.
Your fuel pressure should be about 50 at the rail with the key turned to "ON" and about 58psi with it at idle. Rev it even in neutral & see how much it drops. If you have a gauge you can leave hooked up & take it for a drive you'll see pressure drop under load.
You should be able to pick up a used intake for about $300 shipped, I'd suggest hitting Oriellys & buyin a set of intake gaskets as well, the Felpro kit is good & comes with new foam pads for under the intake as well.
On injectors I'd suggest some 36#, that will be plenty. I'd also suggest contacting the injector sponsor on here, he has a good selection of injectors & good pricing for brand news one as well.
Those numbers don't surprise me all that much. The LS1 engine puts down pretty good torque until about 400-425, then it's pretty much kickin' and scratchin' for much more past that. I believe your problem lies with the intake and the injectors. It makes since to me because down low (rpm wise) where torque is made, the air flow allowed by the LS1 intake is sufficient, as well as the flow of fuel by the stock injectors. However, up higher in the rpm range, the injectors and intake start to become your bottle neck and are choking off your engine's horsepower. This is why I believe you are seeing your torque numbers unaffected and your horsepower number being truncated.
It's the injectors/intake, possibly the fuel pump. it's not uncommon to see higher tq numbers, with short duration cams that don't see hp gain in the high rpms
Honestly if I was you, I'd jump to a FAST 9x/9x set up... I had an LS6 intake after haveing an LS1, just go big from the start. Might want to consider a 85mm maf/bigger air box, while you're at it. Feed that thing some air/fuel and work the tune out.
I was going to run a similar set up, copied from a local. he has 225 TFS heads, 228r cam, LS6 intake, PP-TB, and 42lb injectors. If I remember right he put down 448/442.
I ended up going a totall different route, but I had alot of research into it.
To me looks like verter was unlocked.
An unlocked the verter will flash and cause a big torque spike that is a bit unrealistic so that's one reason you dyno with the converter locked to flatten the torque curve.
