G-FORCE 3.6L Kenne Bell 2011 Trans AM....950 RWHP
8 Sec Tuner
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
We are finished with our TX Mile 2011 Trans AM!!!!! This car makes over 830RWTQ @ 2600 RPMS!!!!!!!!!
2011 Trans AM M6 (50 miles on it!)
948 RWHP
914 RWTQ
The dyno lost its spark signal on the 948 pull so here it is by rpm and mph.
![](http://i728.photobucket.com/albums/ww285/GFORCEROBERT/94836.jpg)
![](http://i728.photobucket.com/albums/ww285/GFORCEROBERT/914rwtq.jpg)
Here are some other pulls past 900 RWHP!!!
![](http://i728.photobucket.com/albums/ww285/GFORCEROBERT/davidson36final.jpg)
TEASER PIC
![](http://i728.photobucket.com/albums/ww285/GFORCEROBERT/IMAG0006.jpg)
http://www.youtube.com/watch?v=gjfFTrTLDVs
- SDPC 416cid LS3
- Kenne Bell 3.6L @ 20 PSI
- G-Force Custom 8rib Bracket and pulley setup (no slip!!!)
- G-Force 102mm KB Throttle Body and adaptor (Thanks LME!)
- G-Force Custom Water/Meth injection
- LG Longtubes and 3" G-Force Custom Catback
- ADM Fuel System
- 80lb Injectors
- G-Force Custom Tune
- Pfadt Full Suspension and Solid Bushings EVERYWHERE!
- Penske Racing Custom Built Coilovers
- G-Force Halfshafts
- Willwood 6 Piston Brakes on all 4 corners
- Custom Radiator
- Spal 2500 CFM Fans
- Afco Twin Fan Heat Exchanger
- Custom Oiling system with Accusump and Huge Oil Cooler
- Custom Trans Cooler
- RPM Faceplated and Proshifted TR6060 Transmission
- Quartermaster 5.5" 3 Disc Clutch
- Quartermaster Custom Throwout Bering and Slave
948 RWHP
914 RWTQ
TEASER PIC
8 Sec Tuner
Platum I'm almost postive there is no way it could make 900+ rwhp with a air/fuel of 20. That's the boost curve (or line) plotted on the bottom of the graph.
But thanks for the tuning tip I will keep in mind that lean is bad.......
