402 LS2 Dyno. Only 460rwhp??
As you mentioned, it's a little hard to make out the numbers... but it appears your HP curve is peaking at 6,000 rpm. what are the full specs on your cam? I need to know LSA and if there's any advance ground in. Take a look at other 402 H/C results and note where they are peaking... usually closer to 6,500 rpm or higher.
Corvette Center in CT are tuning it.
http://texas-speed.com/shop/item.asp?itemid=846
That's my cam. I'm using 1.7:1 rockers though which brings lift down to .614
I still think your using the wrong pushrods if your head is decked. My 408 put down those exact same numbers at first then i switched to the shorter and correct pushrods and hp went to 480 through catback and then to 500 with cutouts open.
I had the motor tuned after assembly for break-in, rev limit was set to 4k and then I put 1k street miles on it.
Intake is an Airaid C6 Corvette LS2 CAI with 4" piping with a huge filter in front of my radiator
STD corrected also. So, 445 or so SAE. That's way low. For a refernce a cam I specked with way less duration for 402 with 10.8 comp and 5.3 stage II's from TSP. Did 460 unlocked (big Yank) and 9 inch. Full weight the car ran 10.9 it's first time out in 2500 DA (summer). So yeah, you should be 500 easy with those heads and cam...
The non ported 78mm Fast, peaked at 6300 rpm. And only down 15 rwhp at 7200rpm.
#32
LS1 Tech Administrator
Looks like it's down 1 cylinder (especially since the dyno numbers are STD). A healthy engine should make close to its cubic inch displacement in torque at 3000 rpm. This 402 only makes about 370 lb ft of torque at 3000 where it should make closer to 400-410 rwtq.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
#33
LS1Tech Sponsor
Either way,they are correct. The corrected #'s we ussually go by are 10-15hp less. I suppose the tune could be off but I'd probly guess not firing 1 cylinder. Hard to say not seeing the car.
#36
After my LS2 402ci is finished I plan on using them again on the new motor..
Funny how some people hate them and others praise them..
#37
This is so not true!! I had the Harland sharps on my H/C/I stock bottom end LS1 and use to spin it to 7200rpm at the track all the time (rev limiter was set at 7400rpm) and never had any valve float issues. My car made 447rwhp and 403torque through a stall auto and a strange 12bolt and ran a best of 10.90@123mph. They maybe heavy on the tip but if properly set up they shouldn't cause any valve float..
__________________
#39
Were you running Trick Flow heads with their standard dual valve springs? If not, then you can't compare results. The TFS heads have heavy valves. The HS rockers are heavy at the tip. The TFS springs are marginal for this combo. Swapping to stock or Yella Terra rockers normally cures the valve control issues.
#40
Hey guys. The motor is in a Mazda RX7 and the numbers seem ridiculously low, unless I'm wrong. It's about 460rwhp/430rwtq with 23 degrees of timing. Here's my setup:
TSP LS2 402 Forged Stroker ~11.3:1 Compression
Trickflow 220cc Cast Heads
Texas Speed LS7S Cam 242/250 Duration .614/.614 Lift on 114 LSA
Spindmonster modded and Ported FAST 92/92
JTR 1.75" Long Tube Headers
3" to 3.5" Y-Pipe
3.5" Custom Exhaust with Moroso Spiral Muffler
The car is still at the shop and I told them to do a compression check and to check the plugs.. Is there anything else I should have them check?
3" to 3.5" Y-Pipe
Just a few ideas:
23 deg spark looks fine, but that cam I question. Those heads eat up airflow at low lift and work well w/aggressive ramps, LSL, XER. Do you have the 0.2 numbers on that cam?
cranking compression check and leakdown. My similiar equiped and IDIOT built 402 (0.0010+ clearanced piston/wall) was 215psi. It was checked w/both a 236/240-112+0 and a 247/255-113+2. Both came out about the same. I would expect yours to be higher. The 112 Had 20rwtq over the other. The 113 got it on top,.
What is the eng vacuum at WOT. If you are at or near sea level, you should not be seeing 100kpa at WOT. If you do, your engine's airflow is stalled. At 6-7000ft, expect around 85kpa. W/cams about I was around 97kpa @ sea level.
smoke the intake check for leaks.
check the valve springs visually. that kind of power loss is usually something significant.
engine tolerances: piston/wall in particular. That cam has 3 degrees ground in advance. If you advanced the crank gear from 0, you are going to be way off. Make sure the crank gear is at 0 or retarded IMHO.
hope this helps.
