Post more A4 dyno's please.
BTW great #`s
BTW great #`s
I would like to ask you guys, since you stall (flash/brake) your verter, when you read a dyno thats locked or unlocked, where do you figure your torque is.
launching your unlocked, the STR builds the massive torque, but you may not always launch at the rpm the dyno operator does, and the gear is obviously different.
So call me dumb, but How exactly do you read an unlocked dyno?
Is it right to say that even though you may dyno 481wft/lbs @ 2500 (like my dyno) its not likely ever to lay down that much, since a full flash (also not likely on nittos) will hit 3800? But then i ask when i brake stand the car at launch say at 1800, then it doesn't flash but hits say 3000 on launch, some of the TORQUE is lost since you are not stabbing it?
I'm a little lost here. As far as i can tell dyno's unlocked or locked are both pretty useless since most people will never do either, from a stop, in 3rd gear.
Are we just hoping to plant our shift exntenions back into peak torque or would it be better to analyze the dyno for peak WHP ?
maybe im not making any sense too early after a friday. That is why i asked for unlocked/locked dyno's. I'm trying to figure out based on dyno #'s (mine) where the best launch, and each successive shift would be. Obviously ive got little control of the shifts (have to get the tuner to edit them) but the launch part is what im trying to figure out.
Seems like A4 dyno's hardly ever represent a real world scenario? locked and unlocked
You wont be at 2000rpm's in 3rd at WOT ever locked up, nor would you be at 2000rpm's in 3rd at wot unlocked? (speaking 3500 stall). So basically does that mean my peak tq unlocked #'s are just b/s since i'll never see that?
with the few new mods added above am now at
330.9 / 344.5 (SAE corrected)
I have to say I am pleased with the results
TIA
Dyno was unlocked and I was only running 25.5 degrees of timing.
http://webpages.charter.net/eyedolx/dyno-11-1-03.jpg
Without the trans problems back when the trans was new after the break-in period and different tuner running 28 degrees of timing this is what car made unlocked.
I don't have the printout but we did a torque spike on a previous run during this and car made 455rwtq on a downshift.
http://webpages.charter.net/eyedolx/dyno-4-1-03.jpg
Now car is on a scaled 25.5 degrees of timing to 30 degrees of timing right before 6600rpm shift. I have a SS4000E -- With PY3600E setup I was seeing 98-100% injector duty cycle at shift. --- now with SS4000E and new tune I am seeing 100% injector duty cycle at 5900rpm and seeing 108% at shift.
No dyno on new setup yet.
multiplication and slippage. Don't know about yours, but the Dynojets I've been on have a very difficult time dynoing unlocked A4s with any consistancy run-to-run. Seems to depend greatly on both dyno operator technique and exactly what you do when you nail it.
Its true most of us aren't locking the converter at all while racing, but it's also true that the real world load your car sees when unlocked is STILL different than being unlocked on the dyno. Just my .02.
2002 Z/28
PP LS6 style heads
224/228 571/591 112
vig 3200
FLP's w orp's
Corsa
bullet muffler in Y
Lid
K&N
ASP
3.73's
On a dyno jet 382, tq was about 342 unlocked
On a mustang style dyno with the same mods as above but with 2.73 gears and no bullet muffler(car was insanely loud) 403 (unlocked) and about 350 rwtq
First time at the track she ran a 12.2x at 111 with the 2.73's and the 1-2 shift at 5500. Haven't had a decent track since the new gears.
