Post more A4 dyno's please.
course you wanna be out of gear when the dyno ends, so the inertia of the dyno wheels doesn't unload into your drivetrain (strapped down) which can break things..
TIA
Mods:
Stock unported LS6 heads
TR224 cam
Hooker LT's and ORP
Borla catback
Shaner TB
K&N FIPK
PT4000
No dyno tricks were used (short belt, cutout, etc). This was w/ 29 degrees of timing.
Mods:
TR224 cam
Hooker LT's and ORP
Borla catback
Shaner TB
K&N FIPK
PT4000
Alittle freakish?
Damn those ls6 heads must be working pretty damn good. Most a4 guys with that cam and stage 2 heads are in the 390-405 range locked depending on boltons. Those are very impressive #`s. Congrats on a great setup
JEremy
SDB
i was runnin stock tb and 26lb injectors a/f was 12.5 lil rich --i shooting for 430ish
i also upgraded my lifters and oil pump--i only got 2 runs in "snapped the tailshaft houseing on the dyno "friggen 2:73 gears mph so fast" one small vibration caused it to snap--this was with the converter locked --
mods lid /cutout/lts/self ported heads/and the 554/575 cam
damn the mang.i can imagine being locked in 3rd and letting off the gas would transfer alot of inertia from the rollers back through the rear end/tq arm onto the tailshaft. Did you throw it into neutral at the end of the run?
good #'s btw.
in my dyno charts in my sig, i believe the tuner did the command 3rd gear, then command unlocked, which is why you see the baseline spike as the converter flashes, then you see the massive flash from post-mod/stall install.
i could be wrong, i can ask him. Either way the point was to baseline a before/after and it did indeed show me some more hp up top
little less than i wanted but i hear A4's its not always about the hp for 1/4 mile. If you notice my dyno, then go to http://www.converter.cc/dyno_shop.htm and see how their graphs look. Seems like thats how your car should look like if you dyno it right (unlocked).
i don't do any runs in 3rd/4th to high rpm's locked up, cant afford the jail time, i dont think i will be locked up in 3rd/4th on the track either, might be too hard on my old tranny
good #'s btw.
i went 11:97@114 on the 2:73's N/A
and went 11.80 with the 3:73s on a 1.65 60' the car was getting faster every run then on run 4 Bang ZZZZZZZZZ crunch crunch ZZZZZZ i was so peaved 11:50 would of been in my sights I shoulda kept that cam it was very nice--it was a lunatti 226/234/554/575@112 might get another one in case this one sux
Then i bought a yank sportsman pro tranny "what a pile of crap " they use such cheezy stuff in them " NEVER BUY A YANK SPORTSMAN PRO" biggest P.O.S. internal parts are crap they use 6 disc 3/4 to where all others use 9
4 pinion planetary -13 vain pump "junk" 1800$ tranny with 100 bux worth of parts in it --get a flp --i will next time
304wrhp with 390 torque
That’s unlocked with a Yank SS3800 on an all stock LS1 engine and LS1 intake.
Ran a 12.58@107 with 1.69 60'
I will be taking it to Ed Wright in a week or two for tuning.
