AI Heads/EPS Cam or Procharger?
#42
If you can afford it, go with with boost, procharger or turbo. Ive had 3 different H/C setups making 430rwhp, 455rwhp & 465rwhp. A TT 6 speed setup making 531/590 on 12psi and making
on 18psi and a TT 4L80E setup making 600/603 on 15psi AND a P1SC on my last Ws6 with a measly 6psi....I'll tell you Boost is more fun (and maintance i might add).
H/C is fun for awhile but then you want more. As long as your motor & fuel system is built for the power, a turn of the **** or a pulley swap and your making crazy power.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#44
Add forged pistons, rods & ARP bolts in the stock LS1 block and you'll be ready for 800rwhp
I never dyno'd the car when it was making 6 psi but on a stock LS1 6 speed, 6 psi would be around 425rwhp.
#47
Captain Double Post
i wish i would have got a used procharger kit from the start , so much more fun and alot more room to grow then your basic head and cam setup, its alot more fun then spray because its always there and never runs out, go with a pro charger with a blower cam you will be very happy you did.
#49
All depends on how you look at it.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#50
If I was to build a fun DD street car with a nice bit of power from scratch.
Used P1sc kit with everything needed (injectors/etc)
EPS blower cam (for the sound and extra bit of power)
supporting valve train
TSP LTs with whatever exhaust one prefers (free flowing yet fairly quiet with no drone)
m6 would keep stock gears, auto would get a small 3200 or so converter
stock 317 heads (they are dirt cheap and nice mod for FI)
stock ls6 intake/ported TB (goes a long way in the FI world)
lid
tune
And I would leave the bitch that way and forget it. 550Rwhp capable safely on 93 pump gas and low maintenance for the most part.
lid
tune
#56
im in the same boat man...i had h/c on my other car and like everyone said at first i was excited about it but eventually i wanted more. I didnt drive the car everyday so actually when i did drive it it felt fast as hell (my daily is an 86 olds with a 4 cylinder lol) but there were times when i was a lil dissapointed with it. I am currently thinking about going with a procharger but the price of FI adds up real quick and like everyone else stated there is extra maintenance involved while with a h/c setup you can just pretty much do regular maintenance and still have a quick car.
