LS2 427n/a #'s not what I thought
Old 08-29-2011, 12:25 PM
  #61
XtraCajunSS's Avatar
Originally Posted by SpinsB
here is what I have. resleved ls2 ported/polished ls1 heads 244/244 612/612 mti s1 cam 90/90fast 1 3/4 headers 3" y pipe gmmg exhaust. numbers came back at 455/460. was thinking and wanting over 500. all thru a m6 car peaked quick at 5800-5900. Guy that did the tuning and dyno said it makes it power quick.
with that said I know there are better heads and maybe even a diff cam that would get me there. I just dont know where to start. any info would be apperciated
There is nothing in this combo keeping it from 500RWHP except possibly the cam. I know a lot of the members on this board haven't been around long enough to remember when the first 408's and such were making 500+ through stock ported 853 castings, an LS6 intake, stock ported TB, 1 3/4" headers, and a hooker catback. I know this is fairly easily done since we and a few other shops from way back did it repeatedly.
You don't NEED high dollar cylinder heads, FAST intakes, massive headers, etc... to get the job done. Any of the above makes it MUCH easier but a well thought out combination of modified stock hardware and the right cam will do the trick. I would find out the exact specs of your combo and have a custom cam ground. With the proper information I could help you reach your goal.
Thanks,
Shane
Old 08-29-2011, 01:05 PM
  #62
SpinsB's Avatar
Pm sent
Old 08-29-2011, 01:10 PM
  #63
SpinsB's Avatar
Originally Posted by Whistler
MTI used to get 500/500 from their sleeved 427s 6-7 years ago with just ported 241 heads, LS6 intakes and through the cats. While there are much better options today such as the offerings from TFS/AFR/TSP or GMs L92/LS3/LS7 stuff, your engine is definately missing 45-55ish somewhere with just the parts you have.
The engine should be checked for compression and the cam should be checked for correct installation and accuracy of the grind.
speaking of MTI I know alot goes into compression ratio's of motors but what would be a good guess of the compression ratio of my motor? Or how would I find that out?
Old 08-29-2011, 04:53 PM
  #64
mike c.'s Avatar
Take it to the track.. I have been on 5 different dyno's and some of them were 60hp difference. I really go by the weight of the car vs my mph. I'm a believer in the high dollor heads for a reason. You get what you payfor...period.
Old 08-29-2011, 04:54 PM
  #65
mike c.'s Avatar
I don't like your heads for power and could get a better cam. Buy some AFR heads from mammo or TRICKFLOW 235 heads from tea. i'll bet you gain 30-40hp like i did over stock ported ls1 heads. forget the ported l92 ****. it makes great peak numbers,but does not perform like the trickflow heads. I know i had them on my 402ci and gained 20hp 15tq going to the trickflow.
WHISTLER-shops can inflate dyno numbers to sell ****. but when you put it all on your car and go to a different dyno it is not close. I have seen this before. I got 540hp on a mustang dyno with a 402ci with trickflow heads.my cam is a 247/255 632/632 111lob.
Old 08-29-2011, 05:17 PM
  #66
blackonblacksls's Avatar
Guys have made 540+ with stock shortblocks and ls3 heads with cams 10 degrees smaller than the guy in the post above me... ls3 stuff would be my choice if I was you.
Old 08-29-2011, 05:47 PM
  #67
mike c.'s Avatar
BLACKONBLACK-Well,i had the ls3 stuff and went to trick flow...DID YOU? I seen the difference on my own set up. the peak numbers were the same but under the curve was a 20hp and 15tq jump and the 1/4 times and mph jumped too. Also my friend,i have had this set up on two different dynos and one dyno was way higher then the other since you wish to only bring up numbers. so,should i hit a dynojet and get a 600hp(because one dyno was 60hp higher)number and say that is what i make....rather keep it real. after 5 dynos and NONE were the same,people still like to talk numbers..lol How mayn motors with different combos have YOU had? I have ran cnc ls1 heads,cnc ls3 heads,AFR heads and trickflow heads on thee different combos. nine different cams,different exhause set ups ect. WHAT CAN YOU TELL ME BRO???
Old 08-29-2011, 09:22 PM
  #68
SpinsB's Avatar
still working things out with what i have now. Waiting on some sponsores to get back to me but I did get a sweet deal on a fast 102 so even tho some say I can get to my goal with what I currently have i had to jump on this 102
I will be sticking with a cathedral port head just not sure what route i will go. Any suggestions on a 102 TB (fast, nw, anyothers?) pros cons
Old 08-29-2011, 10:20 PM
  #69
SHovV's Avatar
did you ever get your oil problems figured out?
Old 08-30-2011, 09:22 AM
  #70
SpinsB's Avatar
Not completely but better. I was getting oil down n the valves thru the rocker arm bolts(they didn't have thread seal on them) but I am still burning oil. Im gonna do a leak down test to see if maybe the rings r bad??
Old 08-30-2011, 11:23 AM
  #71
LS1Tech Sponsor
Slowhawk's Avatar
I think the down low torque curve looks great. The whole top is just restrictions.
Old 08-30-2011, 12:58 PM
  #72
fatmat80's Avatar
before IK bought the FAST I would have done a leak down test. Its almost a given the top end is crap. Doing that would have ruled out your whole combo as crap or a keeper. If the bottom end is good, look at getting a head and cam combo to meet ur needs. If you are on a budget give tsp a call their heads and cam packages are priced great and perform.
Old 08-31-2011, 02:28 AM
  #73
Johnnystock's Avatar
Its all about budget/money anyway and the combination of parts, of course. I wish we could all afford AFR ported by mamo, but its far from the reality. So dollar for dollar LS3 stuff is very impressive.
Quick Reply: LS2 427n/a #'s not what I thought
