Bone stock 5.3/ebay turbo/6psi
motor is a bone stock 5.3
fast 92/92 intake
stock cam/heads/valve springs
Ebay "gt45"- 6 psi for now. waiting on better fuel system before i turn the boost up
Overall i am pretty impressed, made more power than i was hoping for on just 6 psi
Makes 1.5psi at 2000rpms, and makes full 6 psi by 3900
fast 92/92 intake
Well i just got my new 83lb injectors. and it should have came with a fuel pump i ordered also but it wasnt in the package so i got to figure out what happened to that
Turbo-Got for 50$ from a buddy
Intercooler and piping-250
Bov-105
Wastegate-320
3.5" and 2.5" stainless for hotside-180
Oil drain/feed-75
Misc.-100ish
So probably just over 1000 for the turbo parts.
Spent 400 on the motor
550 on 83lb injectors and a DW pump
240 on the brand new cam
300 for a set of 317's to be ported and milled for 9.3cr
Bov-105
Wastegate-320
Oil drain/feed-75
Misc.-100ish
I don't know a lot about turbo's but I do know a lot of members on here run ARP rod bolts when turning up the psi. although the motor is decently cheap I would hate to see all this hard work go to waste from something in the bottom end coming loose. awesome numbers though, can't wait to see the final numbers with all the new toys installed
Im a huge fan of the 5.3 turbo setups, have been for years.... I built a 5.3 turbo setup a few years ago that put down over 600hp and still is alive, it is still being used in a DD vehicle lol!
Most of it is in the tune! Make sure you are running a good tune and itll live for a LONG time!
The following users liked this post:
dave watson (06-08-2021)
