TRex is in and running strong.
Old Mar 13, 2004 | 07:55 AM
  #41
The Juggernaut's Avatar
Don't be disappointed when you run 11.30's.
Old Mar 13, 2004 | 08:58 AM
  #42
XFiveLiter's Avatar
Originally Posted by SMOKIN01TA
hopin to beat the 10.93 cam only record.
should weigh in around 3400 with me i hope.
ill post up the first track times for this cam monday evening.
I don't think its gonna happen at 3400#. Good luck though.
Old Mar 13, 2004 | 12:08 PM
  #43
GrannySShifting's Avatar
So it made around 420 hp 390 torque then?
Old Mar 13, 2004 | 12:56 PM
  #44
CHRISPY's Avatar
I think you'll hit around 11.1-11.2 depending on traction and air of course Still good though
Old Mar 13, 2004 | 01:14 PM
  #45
SMOKIN01TA's Avatar
haha. well for you ill try that. dont be disapointed if i dont.
Old Mar 13, 2004 | 01:15 PM
  #46
SMOKIN01TA's Avatar
im leaving now. i know i still have a ways to go on weight reduction, but im going to shoot for the sky. if i get some really low 11's ill be ok with it for now.
Old Mar 13, 2004 | 02:09 PM
  #47
x phantom x's Avatar
STF veteran / 10 second club
I figured that 420-430rwhp would be a more realistic amount of HP for this cam. Somewhat dissappointing.
Old Mar 13, 2004 | 07:34 PM
  #48
We make the same power, I was 350# lighter than you.
Good luck
Maybe I just can't drive.
Old Mar 13, 2004 | 10:01 PM
  #49
2001 Pewter WS6's Avatar
Restricted User
I don't think it is going to happen. Don't get me wrong, I hope you do but it takes time to get the car all dialed in. You just can't slap a cam in throw on some slick. Install a 12 bolt and think you are going to run 10's. I say 11.35 -11.40 maybe if you are lucky.
Old Mar 13, 2004 | 11:54 PM
  #50
SMOKIN01TA's Avatar
jason went 11.2 on his factory motor with the tr230 cam at 3350 lbs. it all depends on how good the track is hooking and how good you can drive.
aint no way im going 11.40 unless track prep sucks totally.
Old Mar 14, 2004 | 02:42 AM
  #51
Good luck
Whew, dem der some fightin words.
Old Mar 14, 2004 | 06:40 AM
  #52
offaxis's Avatar
Good luck !
Cant wait to see the results
Jeremy
Old Mar 14, 2004 | 08:47 AM
  #53
SMOKIN01TA's Avatar
ok, i unfortunatly change my prediction. i might break 11's with these conditions. it isnt raining, but it is soaked outside.
Old Mar 14, 2004 | 04:00 PM
  #54
CHRISPY's Avatar
He is running a 12 bolt with 4.56 gears though. That is still good IMO What were the actual dyno numbers?
Old Mar 14, 2004 | 04:05 PM
  #55
EVIL's Avatar
430 with just a cam aint bad at all!
Old Mar 14, 2004 | 04:34 PM
  #56
I agree ... and this cam is definately still going in my car ..... I have just been telling myself it was only going to be good for 420-430 and not to get my hopes up for a 455rwhp cam only car .... then when the results came through I was somewhat dissappointed that I was correct.
430rw is definately good enough for me ... just that 455 would have been abit better.
Smokin ...
where are our soundclips???
Old Mar 14, 2004 | 08:53 PM
  #57
Joe "Preachers Sheets" DIESO's Avatar
Humanitarian
I installed my T-Rex. Put it this way, the car sounds like a 9 second solid roller motor. Amazing man. When my car is tuned we are gonna post video's, dyno #'s and all. The tuning is key but even with 3.42 gears I can cruise @ 1,600 rpm without any bucking, idle on hot/cold starts is fine I leave from a dead stop by keeping the rpm's @ 1,000 then giving it gas to keep it rolling.
I could keep the 3.42's, the cam is very street friendly.
Old Mar 14, 2004 | 09:16 PM
  #58
EVIL's Avatar
if i get 400-410 from my th400 car with 4000 stall, im gonna be silly!
then see what the 250 direct does to it.....
maybe it will not only sound like a 9 sec solid roller, but run like one!
Old Mar 15, 2004 | 08:24 AM
  #59
CHRISPY's Avatar
I am happy to hear these driveability reviews With my extra cubes (16) it should help swallow up a bit of the lope as well.
Old Mar 15, 2004 | 08:59 AM
  #60
Restricted User
I am wondering if it will be more street friendly than my 236/240 is. Mine is on an XE-R Lobe. Are these lobes as radical? How much valve train noise do you have with the T-Rex?
