243s + TR220 dyno and track results
#84
great numbers ,kinda sounds like a Pat-G project involving a ls6 motor and a small EPS cam.the new Y-pipe will help.you should be running 10.90s.you don't need a big cam to be quick.
#85
The y-pipe hurt me about 5 rwhp up top and the cam hurt it 3 rwhp up top and 16 down low. I did gain overall with the exhaust by modifying the tailpipes but the dyno was in STD and not SAE so once the number were corrected they weren't as high as I originally thought when I posted that.
#91
I don't know. I'm gonna try a different merge setup in the y-pipe. It just has a weird sound to it now at WOT. I just wonder if something is going on that isn't flowing like it should.
No idea about the cam either. Everything I checked was fine. The TR220 is back in it just to double check my results and I'm gonna check the new cam out and make sure it's ground properly.
I'm working on that right now.
#95
I had a local (retard) exhaust shop change the tailpipes on it from the 3 inch magnaflow tips to Corsa clones. And in doing that they added some 2 1/4" pipe to the mix. I cut those tips off on the dyno and gained like 12 rwhp down low and 8 up top (or something like that). I'm gonna redo the tips with 3 inch pipes out of the Magnaflow muffler.
I'm probably gonna switch to a Flowmaster merge with a 4" out and run that into a 4" dynomax bullet then reduce it back to 3 before the axle.
Didn't tear anything up. Just had an incident that made it a little more convenient to freshen up my bottom end.
