What do you think about my numbers?
- True ram air hood and lid by Suncoast
- ASP under drive pulley
- LSX manifold 78mm
- Home ported throttle body
- MTI C-2 cam on 112 (224-224,581-581)
- Heads by Westside Performance- 205s flow 315 & milled .030
- MACs
- MTI custom tuning
- Cut out
- 160 stat, and TB bypass
- TCI 2800
- 3:73
SAE corrected: 395.9 RWHP @ 6200 & 376.7 RWTQ @ 4600 with converter locked up on MTI Dyno Jet model 248C
I was hoping for about 410 RWHP range. Im I being realistic? Are the MACs holding me about 15 hp back?
What do you think
Thanks in advance!
I would be curious about LT's also but I would also be pissed if I got them and it made no difference. See how you do at the track before you go changing things.
That would put u at 350RW with stock heads,This guys numbers arent bad.
Like 9T9 said,real world numbers..
I'm getting sick if the net and all the inflated bs...
Locked A4 dyno's have more PWHP and less torque.
Unlocked A4 dyno's have less Peak whp, and more torque.
Not flaming anyone but the dyno is a tuning tool, if you want to know whats what we need to go to the track.
I have seen way to many high dyno guys not put down good track times .
I dont agree with half the dyno #s people post cause they really never match what the car runs.
We all know every dyno ,dynos different.
tracks vary too, so does driver skill. DA , Track prep, launch skill blah blah. you are right there. Thats why i asked if he baselined.
i still stand on my point that locked runs produce more whp/less tq/vice versa.
I did have nitto 275/40/17s all the way around on the car. They hooked up fairly well. When I really stomped it off the line I got a few wheel hops, but never really broke loose, sure was a lot of fun-ate up a few mustangs, anyway here they are:
7.73 1/8 @ 89 mph
60 ft time of 1.74
Im thinking of ETs with lighter wheels and smaller tires on the front, 3500 stall speed and hooker longtubes and that might get me into the 7.5 range which is my goal of a 11 second street car on motor only.
What do you think?-thanks
your tire scenario will probably get worse with a larger stall. might think bigger than 3500 imo if you make alot of top end. the tci 3500 shift extension is below 5K kinda sucky imo.
the bigger the verter, the higher the shift extension (generally). say if your dyno makes peak power from 5500-6600 you want to spend the most time in that range going down the strip. right now i'm shifting at 6100 then dropping to 4600. I can bump the shift points up a little but i dont think i'll get 5000 shift extension (or more) from the verter i have.
You're numbers sound pretty much on. Reading your mods - I was thinking should just reach 400+rwhp - but you are right there. LT's would pick you up some - but I would think 5-8rwhp is probably all. More stall, more tire and maybe some more dyno tuning (LS1Edit) will probably get you where you want to be without the LT's. Good luck and hope to see you around... Patrick
Last edited by 1999Daytona500PaceCar; Mar 26, 2004 at 02:05 AM. Reason: correct spelling
