Think my numbers are way low: ls6 baby cam long tubes
2005 CTS-V
Stock intake
Pacesetter 1 3/4" long tubes
No cats
Stock x/resonator
No mufflers
EPS 226/226 .598/.598 117+4
Copm 918 springs
7.425 pushrods
Tune by me
27 degrees timing
A/F @ 12.8
Can post hp tuner logs tonight if anyone wants to look at them. Look normal. 87% duty cycle 43 #/min on the maf up top. Looking at the log vs other cars I have tuned it should have made way more power. Hell the 425 rwhp vette I did earlier this year had basically the same maf flow and map readings. I was only seeing 92-93kpa with the filter out but still thats about normal on other ls6 cars I have seen.
I know I am running a blower or emissions cam but does the 117 really hurt that bad. People make my numbers with just headers. Can't afford the blower right now - if a cam swap will pick up another 40hp I'll head to the for sale section. Stock on a different dynojet I made 330.
Thanks to anyone who looks.
Stock intake
No cats
Stock x/resonator
No mufflers
Copm 918 springs
7.425 pushrods
Tune by me
27 degrees timing
A/F @ 12.8
![](http://img21.imageshack.us/img21/158/jeffjb.jpg)
364 rwhp for a small cam only 5.7 seems on par to me, my cam only 6.0 LQ9 only dyno'd 388 rwhp with a muuuuch larger cam. ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Take it to the track see what kind of ET it turns, those are the only numbers that count anyways.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Thats what my kit came with. I didn't measure. Reading posts it seems to be a mixed bag of 7.40 or 7.425. I could throw my stock ones in pretty easily. I would expect the car to run rough or break up or something.
I do smell unburnt fuel at idle even after leaning it way out and running timing up and down. This cam has no overlap.
It's cuz you have no cats, I have the same cam on a 115 and can smell gas. I've seen a couple other guys have the wrong pushrods in and the car seemed to run fine,maybe a little valve train noise, but were just down on power. Just a thought . You should be higher than that with just LTs, I would expect you be at least 400rwhp with that cam.
my 2005 CTS-V made 330whp stock, they sure dyno low, but i would expect more then 360whp with cam and longtubes.
I have almost identical cam in my M3 with 116LSA made 400whp, but I have TSP Terminator heads.
My 2004 crate LS6 with longtubes and a lid put down 365/359 on a Dynojet. I've quit worrying about dyno numbers, I look at trap speed as a judgement of power.
And IDK if I'd order pushrods before checking the 7.425's that are in the car. I just ordered a 230/238 from EPS and Geoff recommended 7.425's....
My guess is 385-395whp would be what your car would put down.
For what it's worth measuring is a MUST. Geoff recommends 7.425 with stock headed cars, my heads are shaved .010 and use stock thickness gaskets and an older set of Vortec lifters.
Using 7.4 pushrods I am right at 2 turns to 22ft/lbs from zero lash which is on the high side of acceptable if I am understanding correctly. I am going to measure with my pushrod tool in the near future and I expect to end up putting 7.375 pushrods in.
Let us know how you like it, I am loving mine. It is stronger than my old 230/224 reverse everywhere (but some of that is the heads too)
It will be installed with the help of someone who has done this multiple times before. I'm buying a valve spring compressor today and I'm anxious for January to get here so I can haz my cam
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
So back to the point for the OP, Geoff recommends 7.425 pushrods on stock heads for a reason. The base circle of his cams are different than stock, IIRC
I'm going to call him this morning. Will be after Christmans before I can measure them. I'll report back but seems most of the comp cams change base circle right around .600 (I know this isn't every case)
As far as I know the motor is healthy. Made what it should stock. I'll check in later.
He said same thing - 7.425 on all his stock stuff. Geoff doesn't recall this cam though. Trying to contact the person who bought it to see where he got it. Going to measure either way. May just pull it out and grab an NA cam, pass this one off to someone going turbo/blower.
