LS3 414 results Video added
there seems to be quite a few variables as to your "low" number, but it looks like a pretty strong running car. Keep tuning her and get the timing down to where it needs to be. What exhaust and headers combo are you running? also, i have read that the ls3/l92 style heads like a cam with at least 10 degrees of separation on the duration. unless you're happy with the overall combination, get in touch with pat g and see what he suggest for your set up, otherwise once that car is all tuned up and running properly, enjoy it man!
It's not that ls3 heads want a certain cam. That's more intake/exhaust dependent IMO. I'm running kooks 2" headers and 3.5" true duals. These are just preliminary results for now until it warms up a little and I get it all ironed out. On one of the pulls it says it only made 460 ft lbs. with 220+ cranking compression. I don't see that being correct.
I'll see if I can get the vid up tonight.
Still quite a bit of tuning to be done but pretty happy right now. Car is a monster!
4.060x4.00 iron block
11.5:1 compression
L92/ls3 style heads
GMPP single plane
scorpion 2000 CFM 4150 throttle body
258/259 .714/.698 108 LSA solid roller cam
8000+RPM![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
6speed with spec dual disc and moser 12 bolt
http://youtu.be/K83cMHPHudY
http://youtu.be/_1wyR9LZ4Hk
11.5:1 compression
L92/ls3 style heads
GMPP single plane
8000+RPM
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
hows the drivability with that cam? what gears are you running?
Also, how hard was the tuning?
"iron block" Meaning LSX or LQ block? What rods are you running?
Personally I would be scared to spin that high with our style of oil pump. Why did you want to spin that fast anyways? I want a horsepower/torque vs RPM graph..
Couldn't get a good graph cause for some reason the dyno wouldnt pick up rpm over 7k. The block is a LQ block filled with callies compstar crank and rods with ceramic coated pistons. Im running a moroso pump and pan using a total of 8 quarts of oil. I have had torque monster cars before and they just don't do it for me. I'd put a 700hp high rpm car against a 800hp low rpm car any day. This motor is also built for a 300-400 shot from a direct port I have set to the side in the garage
I have had to completely stop working on the car. My baby girl has been born and is here a month early!!! It's an incredible feeling. I'll update this in spring most likely!
Couldn't get a good graph cause for some reason the dyno wouldnt pick up rpm over 7k. The block is a LQ block filled with callies compstar crank and rods with ceramic coated pistons. Im running a moroso pump and pan using a total of 8 quarts of oil. I have had torque monster cars before and they just don't do it for me. I'd put a 700hp high rpm car against a 800hp low rpm car any day. This motor is also built for a 300-400 shot from a direct port I have set to the side in the garage ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Congratulation man!
#32
Why wouldn't you pull it as long as power doesn't drop off much? There is still more power to be made im sure. Found out tonight I bought a use rear with a bent axel and it's causing the rotor to drag on the brakes. The builder says he would put more than 24* of timing in it. We are just being careful since there are no knock sensors anymore. Might try E-85 and 32* of timing ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
If your tuner has a clue what he's doing, he will be reading the plugs and giving the engine timing it wants instead of guessing at a number and calling it good.
#35
I'm sorry I have to respond to this.
11.5.1 and a 300 shot is nothing.
Have you ever spent any time around a serious nitrous car?
I know more people than I can count on two hands that run 400+ worth of dope through their motor's at 12:5.1 compression if not more some are around 13.5:1. Tuning window gets narrower higher compression you go, but with race gas and someone that knows what they are doing and the right plug there is nothing wrong with it.
#36
