My dyno numbers
Old Feb 28, 2012 | 03:40 PM
06SpiceRed's Avatar
The heads have been milled to 62cc or 59cc not sure but no porting and the fast is right out of the box and throttle body has been ported.
Old Feb 28, 2012 | 04:54 PM
_GTO_'s Avatar
Originally Posted by 06SpiceRed
Yup i agree also, i ordered the Svede intake last night should have it in a week and a half How do you like yours?
I love it so much , The car pulls so hard on high rpm and reads lower IAT .
I bet you'll gain 10+ rwhp on your setup with Svede intake.
Old Feb 28, 2012 | 09:03 PM
Slowhawk's Avatar
LS1Tech Sponsor
The power looks good for the setup. The intake hurts alot and also the exhaust. I really like the Kooks dual 3" setup and switch the midpipes to 3" instead on the knocked down one's. Cleaning both of those up will show big torque gains.
Old Feb 29, 2012 | 07:17 AM
06SpiceRed's Avatar
So how much is the exhaust hurting my numbers and what could i do about the fast 102 to get more out of it?
Old Feb 29, 2012 | 08:50 AM
Slowhawk's Avatar
LS1Tech Sponsor
The FAST is fine. It's the intake piping. We ussually do a custom 4" pipe which helps alot.
For exhaust gain, best test is to dyno it open headers and see.
Old Feb 29, 2012 | 10:14 AM
bad94sup's Avatar
I agree the intake/exhaust exhaust could be a major restriction. On my 402 (Formula) I gained 20whp by switching from an SLP lid and stock MAF to a 104mm FTP lid and Z06 maf. I picked up another ~45whp or so from going from a 3" y and hooker catback to a TSP true dual setup. The intake/exhaust switch took me from 445whp to 511whp/480wtq! My car also tuned by RPM. The tune is NOT your issue, I can assure you that.
Old Feb 29, 2012 | 11:02 AM
06SpiceRed's Avatar
I know its not the tune ,I just dont understand with the mods that i have already why i wouldnt get the results that im looking for. when it was just a heads &cam car without the 402 it was making 460 or 470ish then with the 402 went up to high 480's low 490's now with electric water pump,1 7/8 header larger cam i picked up 6rwhp ?
Old Feb 29, 2012 | 11:36 AM
bad94sup's Avatar
Think of the motor as a simple air pump. Now you've increased the volume of air that the motor displaces, you now need a way to more effectively move air in/out of it. With more displacement comes new bottlenecks in the way.
This stuff never ends, heh.
Old Feb 29, 2012 | 11:44 AM
BrianSF-GA's Avatar
Your airbox/intake tube restriction (not as familiar with the "Goat") and the 2-1/2" exhaust is hurting, but, I think it is something more than the FAST 102 and 1-3/4" headers ... here is my graph. The only difference between the "green" graph and the "blue" graph is the addition of a SDPC 402 short block. This is through a Vengeance ported FAST 90/90 NWTB, CNC'd TFS 215's and 1-3/4" Kooks into a 3" ORY and 3" dual-outlet Flowmaster. You must be pulling in the same or more with your "out of the box" 102.
I believe all of the TFS 225's are cnc'd and the as-cast is the TFS 220 ... someone can correct me here ... so I believe your head flow is fine and more than my TFS 215's.
Old Feb 29, 2012 | 12:50 PM
06X6spdGTO's Avatar
As cast is the 220 trickflow. Things to consider is how much the trickflow head was milled, what the static compression is, what fuel are you running, what head gaskets were used, was the piston run out of the hole when the short block was put together, what pistons, etc....
ive played with 2.5" catbacks to 3" catbacks on my blown GTO with no noticeable gains. Maybe 2 to 4whp. But that couldve been the day. Hard to say?
Old Feb 29, 2012 | 12:56 PM
06X6spdGTO's Avatar
Not a firm believer in the svedeOTR intake either, the short runner length and placement of the maf sensor can make a larged cam car are real turd for street manners. With the long intake runner tube of the LPE, powerchamber, etc... the intake place the maf farther upstream from the throttle body alowing a steadier flow of air across the maf. Creating a better running better tuned car.
Old Feb 29, 2012 | 12:57 PM
  #32
06X6spdGTO's Avatar
Plz excuess the grammer in my last post. This is done from my lovely droid!
Old Feb 29, 2012 | 05:07 PM
  #33
06SpiceRed's Avatar
The car has the 225's I don't know if that matters, wesico pistons callies crank heads were milled 59cc. Don't know what the static pressure is, running 93 octane
Old Feb 29, 2012 | 06:09 PM
  #34
06X6spdGTO's Avatar
-8cc Dish Wesico's?? Any specs on the deck??
Old Mar 1, 2012 | 01:20 PM
  #35
06SpiceRed's Avatar
this a copy of the dyno i was wrong it put down 503rwhp and 458rwtq.
File Type: pdf
Old Mar 1, 2012 | 06:20 PM
  #36
Demonicbird00's Avatar
congrats!
i saw the cam size and i thought it was RPM! Roshan spec'd that cam for me as well but on a 111 lsa for my stock cube 346
btw the dyno does show lower numbers compared to others around
-brandon
Old Mar 1, 2012 | 07:18 PM
  #37
mikh338's Avatar
i have a SD tune so not using maf and have the stock intake piping and maf hooked up to an slp lid. i want to take all that out and get a smooth intake pipe directly into the ftp 104mm lid. do you have any suggestions what piping i could use to fit this? i may have read somewhere the 104 lid is 4 1\8 i.d? what is the o.d of the stock tb? going to be a wierd setup
