PRC As Cast Heads Dyno Results on 01 Z06
#42
Trickflow's dont require Aftermarket rockers either, just get the TEA spring package and grind down the stock rocker stands. install the comp trunion upgraded stockers and your good to GO!
BTW Texas Speed my offer still stands, back to back 1/4mile track comparisons for your PRC LS1 AS cast heads vs my Trickflow LS1 220 As Cast heads. Car is a full track car 82' Gbody with a stock bottom end LQ9, Powerglide. Only changes would be heads and fueling both setup to 12.8:1-13.0:1 AFR @ WOT on the wideband of course.
#44
06x6,
Id be more interested in a side by side same day engine dyno & flow bench comparison. Would you be interested in that?
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
#45
As far as comparing to the 215s I guess it all depends on the combo.
I really like the PRC 227 heads, they are without a doubt the best 3.9" bore heads available. the as cast was based off that head so while it doesn't move the air the 227 head does, it still performs awesome & I'd put it against any other LS head on a 3.9" bore no problem.
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
#46
Jason,
You guys just need to do a dyno with the TFS 215 vs. your PRC 215/227. I have no doubt that your PRC will stack up to the TFS. You guys def have came along way. People are still stuck in this illusion that PRC is just a budget head.
I would just post up the charts, screw everybody else feelings..
#50
All variables should be the same including the car/drivetrain/tire with the only difference being the heads.
#51
I don't seem to understand why so many people want compared to brand X
heads as controlling all the variables becomes very difficult. From the pics
and now results provided it appears to me that TSP has poured their heart
and soul into a cost consious design for the 3.9" bore AS CAST market.
No more or no less.....I mean 30 horse over the LS6 243 casting with about
6 more cc of intake volume, that is very impressive !!! Port speed, air velocity
and throttle response will be tremendous.....Great job.....
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
#56
The car gained right at 30hp & 24lb ft of torque! That's a awesome gain over a LS6 head
Idk if it's just me but I had more expectations for the as cast PRC heads. I was looking at them extensively due to the great price point and hollow valves, but if that's really all the power they pick up over OEM 243 heads it might not be worth it. I've seen ported 243s pick up a good 35-40rwhp over the OEM 243 castings, so if these only pick up 30rwhp then that's pretty dissapointing.
#57
LS1Tech Premium Sponsor
Hopefully the OP still remembers about this build and can reply, but were these gains over a ported LS6 heads or a stock casting?
I understand where you are coming from but keep in mind peak horsepower was not the only goal with this head. Our aim was to offer an aftermarket casting head for an affordable price. While a hogged out 243 casting will make the same if not more peak power, it will end up leaving low end power and throttle response on the table. We are able to offer a thick deck, 6-bolt casting, laid over valve angle, and smaller chamber for a very good deal. In the process of trying to offer all that, the head ended up making 30rwhp over a stock 243 in this test. For what its worth, we have had multiple cars make slightly over 500rwhp with these heads in ideal conditions.
Thanks
John J
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
