My Dyno results...
Old Mar 24, 2004 | 07:45 PM
C5kid's Avatar
Default My Dyno results...
Ok here are the mods first
LS6 Intake
LS6 Heads
SLP Cam 214/222 .559/.566 115
Meizere EWP
ASP U/D
DRM LT heards w/ Stock exhaust (Cats on)
K&N Filter
Predator Tune (not sure how good it is)
Fidanza Alumiumn Flywheel/ SPEC III Lite Weight Clutch
Ok I was hoping for 400 but you know how that goes but I am still very pleased to get 377rwhp 380tq SAE corrected.
Do you think I could of gotten more? Any input appreciated...
Old Mar 24, 2004 | 07:57 PM
gomer's Avatar
If they are stock LS6 heads I would consider that pretty good thru cats. What type of valve springs are you running? The graph takes a little dip there about 5800. Also do you know how much advance the cam has ground into it? If you have the cam card subtract the LSA from the ICL. A ported TB, and ASP pulley are good "dyno" mods.. along with some cutouts and and offroad pipes.
Old Mar 24, 2004 | 08:01 PM
C5kid's Avatar
4* of advance are ground in it...
Old Mar 24, 2004 | 08:02 PM
C5kid's Avatar
oh yeah yella terra rockers too
Old Mar 24, 2004 | 08:03 PM
C5kid's Avatar
and stock 02 LS6 springs for got that in the last 2 post
Old Mar 24, 2004 | 08:10 PM
M6HuggerSS's Avatar
what stage are the LS6 heads? and who did the porting?
Old Mar 24, 2004 | 08:17 PM
C5kid's Avatar
i cleaned up the exhaust ports myself and took some of the excess around the intake vavle
Old Mar 24, 2004 | 08:28 PM
M6HuggerSS's Avatar
ok....that makes sence, those numbers sound ok then........i thought you had a sponsers head and that your numbers were very low................never mind.
Old Mar 25, 2004 | 07:34 AM
gomer's Avatar
Change those springs to some 918's an you'll loose that dip in power at the top end. I bet you are getting a little valve float up there. Keep you eyes open in the classifieds and you can get some for around $75 sometimes.
Old Mar 26, 2004 | 02:06 AM
jmX's Avatar
jmX
Yeah, i wouldnt run that cam with yella terras and stock LS6 springs. Some 918's would probably be better.
400rwhp is only a cam swap away
Old Mar 26, 2004 | 04:11 AM
C5kid's Avatar
how much would a set 5.3 Stage 1-2 heads help me??
