cam only 5.3, PT7675, 16psi, 824fwhp
2005 L33 5.3
stock except for 224/228 cam, head studs, LS9 gaskets.
LS1 intake
E85
truck/LS4 manifolds
96 Delphi injectors (90% duty cycle)
16psi
Precision 7675 CEA .96 AR
4" Downpipe
Treadstone air to air
75-130 IAT's
17 degrees timing
11.5 AFR
LS1 intake
E85
truck/LS4 manifolds
16psi
4" Downpipe
75-130 IAT's
17 degrees timing
11.5 AFR
Ugh That car is sexy
...... Im looking to put a 5.3 in my car and make 700+ rwhp. Congrats on the number. How much did the old 370 make and was the master power turbo used on both motors?
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
Next step is Im looking at throwing some Wiseco's and Eagle rods in it so I can safely max out the turbo and see if I can hit 900rw through the 80E and 12 bolt.
