PP LS6 stage 2 heads inside
445.1PH 397.1 torque cam and mods below
2000 Trans Am M6
stragge 12 bolt rear 410's
lots of suspention stuff
PP heads LS6 stage 2's
texas 231/237 cam
double roller chain
LS6 intake and ported stock throtle body
pace setter headers we dynoed with the cut out open
there is more mods to come i will keep posting
<--------waiting for the tea nut-huggers to be in here saying those number suck
Just curious, what compression/timing are you running, and do you have a dyno sheet to post?
BTW, congrats on your #s. Looks like a stout setup.
first off my total timing is 30 and its stock compression
ran on cheep pump gas 93 octain
rice eater be carefull that Magic stick 2 needs relief cuts in the heads i tryed the magic stick one in mine and that does not work either
i will try to scan the dyno sheet and get it up
as far as PP i would never deal with any one else Terry has been such a help
BTW there are bigger numbers coming from this set up as soon as i get time to do a few more things
track times as well
Thats through a 12 bolt too
In some of the lower dynoing combos how do you know there isn't something else going on besides the heads?
Look at JS. He was worried about the short, whether or not the cam was advanced etc. He was unhappy with his new numbers but picked up over 20RWHP with a RETUNE on an already Cartek tuned package.
Most of the time it is not the heads at fault but some other problem in the combo that needs to be identified and fixed.
I think you need to look at the net gain before and after mods/tuning. Drive in and dyno the car. throw in the heads/cam, tune and redyno. If you gain 80-110 HP (depending on cam) you are doing really well.
honestly , i could careless about dyno #s. we would be more impressed with track times.but congrats on the good #s,if that makes you feel better.
p.s.i am not flaming you or PP, i am just tired of all posts about PP users trying to prove something with good dynos, or trying to make an excuse when they have shitty #s.
..and i dont have TEA heads. i have GTP S2+ 5.3.
There are a lot of great track times from all the sponsors including PP. Look at Camarocain or Trevor etc.
first day out on the car
here is my dyno sheet
http://www.fandsracing.com/dyno4453972.jpg
All the shops on here put out decent numbers given the package.
Chris I actually picked up 13RW PEAK over my Cartek tune.
But I'll get the sheet scanned,u wont believe the mid numbers
Good luck with the new setup..
Verbs, How do you know some of the heads aren't good? Have you flowed them? Had them in your hands?
