Dyno results. Have questions.
1. How rich is the actual engine since the cats lean things out? Do you think there is 10hp in leaning things out to 12.9-13.1? The first run was 12.1 afr put down 309.4rwhp and 323.6rwtq.
2. The dyno said I was going 116 mph at 5500. I should have been going 124 mph. That is where I get the 7%. The math works out to 335 rwhp and 352 rwtq going from 15% drive train loss to 21% drive train loss. Do these equasions warrant any marret? Those were about the numbers I was expecting.
3. What do you think I can pick up with the LS6 manifold and Hooker 1 3/4 long tubes and ORY?
I just want to get to 350rwhp and 360rwtq with bolt on's.
If I am off track with these comments, I'm sure someone will correct me.
The afr was 12.3:1. is what I ment to right. But that is after the cat which thins the afr due to emmissions. The sensor was in the end of the tail pipe.
The dyno reads the mph accuratly. But if you use the equasion MPH x rear gear x trans gear x 336 divided by tire diameter. You get the correct mechanical rpm for speed. Mechanicle speed at 5500 should be 124 mine was 116. That is where I get the slip. Same with auto tranies.
Anyway, I don't think your number are that bad. I use 12-15% parasitic loss for my M6, 10-bolt driveline. A4's with stock convertors should be around 18-20%.
For comparison purposes, I dyno'd at 321rwhp/338rwtq...SLP lid, o/r y-pipe (no cats), stock manifolds, and a poorly modified flowmiser muffler
(not my doing, believe me...it will be history shortly). I too expected more, but once I get a REAL catback, I expect a tad more. We have better flow exhaust manifolds, but our cam specs are lower than the earlier models. (Emission Gods have too much time on their hands)
Get yourself a new clutch. I replaced mine at 36k miles. For applications below 400hp, I went with the GM Z06 (OEM for the '01-'02). That clutch is much better than your OEM for a '98. SPEC makes a good setup too. I think you'ld see more, but you won't really know until you've dyno'd it again.
