Simple combo-big power-347+D1SC=800+rwhp
maybe on a stock bottom end. I've seen a guy here locally who made 717whp on his TTi vette for several years now on a stock bottom end LS6. Well he blew that motor a while back but still it held up for a good solid few years with many mid 9's to low 10 1/4 passes.
Killer D1 set up, is the blower being overspun to achieve this hp?
No, I mean actually the stock block itself. I guess the folks at Hitech told me a long time ago that even with good internals, the blocks car squirm around enough to cause bearing issues and whatnot at higher hp levels. They used to fill stock blocks at a certain hp range (I thought in the mid-500 range) to try and keep the block together. Maybe this was all a dream I had? LOL.
My buddy from Kentucky just let me know that his low budget made 800+ through stock 243 heads on Bluecats dyno.
Pretty much same combo but a 2200, and 243 heads.
UNDER PRESSURE MOD
Seeing this now makes me feel bad about my results yesterday.
https://ls1tech.com/forums/forced-in...dynod-car.html
I dyno'd 742/688 with spinning the D1SC close to max rpm, but only made ~17.3psi of boost. I'm wondering if going to some 1 7/8 headers would help, maybe a larger intercooler. I'm not looking for every detail, but what was the cam size and about how much timing did you throw at this car?
