why are my dyno #s so low??
They guy at the shop told me that his '00 T/A only put down 292rwhp, and a few other Z28's he tested were making #s similar to mine, so maybe the dyno just reads low or something. It was hot and very humid (typical florida weather) this may have played a small part also, I dont know. Please give me your thoughts. thanks here is the thread, must be low tq numbers out there. :shrug:
https://ls1tech.com/forums/dynamometer-results-comparisons/159407-yet-another-tsp231-237-stock-heads-9-a.html
lata
bill
thanks again
(sorry for the poor quality, the scanner at work is ancient)
lata
Bill
FWIW, I don't think it is the car. Could be a wrong scaler input into the dyno. The HP curve looks good though. Just the Torque curve looks all fooked up.
thanks guys for your info!!
Seriously, those are not bad numbers, but generally torque will always be higher the RWHP on LS1s. Unless, something is wrong. I suspect there may be reading your next post that was moved.
The main thing about dynos is make sure you use the same one, and as close to the same atmospheric conditions as possible. I have seen people claim these LS1s make 345, even 356RWHP bone stock! And we all know that is BS! It boils down to what the owner of the Werk dyno on the Hot Rod Power Tour told me. "If you took your car to a dyno facility, and the numbers were low, in your opinion, would you go back? Of course you wouldn't. That is why most dyno shops tweak their dynos!" The key is go back to the same one.
It makes sense, too, think about it. I see so many ridiculous claims and even dyno sheets posted. The simple fact is, most LS1s and LS6s (that are stock) are within 10% of each other. It really doesn't matter what the dyno says, look at stock 1/4 runs of Fbodies, they are consistently the same, given a qualified driver. However, in the hands of a competent engine pro, these LS1s can really deliver the HP and Torque!
The first point was proven by my 2000 Formula VS my fairly new 2002 Firehawk, on the 2002 Hot Rod Power Tour dyno. The 2000 had a 3" exhaust system, stock manifolds and a K&N filter and was within 14RWHP/10RW ft.lbs. Torque of my new 2002 Firehawk! That Firehawk suposedly had 345HP vs what, 310! That's within 3%! And, we know the 2002 has the Donaldson air lid (Blackwing), the LS6 (2001) intake, and SLP's dual/dual catback exhaust.
Funny, those two were so very close to each other!
Joe Jill, who won the Hot Rodding Mag Engine Masters Challenge last year, with a LS6, at 550 RWHP! WITH NO POWER ADDERS! That tells me there is a lot to be gained IF you know what you are doing with valve train, heads, moving air in/moving it out, coatings, oil windage, etc. etc.! They can really boil the competition, which is what it really is about. Not, who's dyno posts the most numbers. Take it to the track and kick some Mustang butt! That's what I say.
thanks again
What are the inlet/outlet dimensions of the moroso spiral flow in your I-pipe? Do you know anyone else running that muffler in the I-pipe? Speaking of which, how do you like the sound coming out with that muffler there? Did it pull all the drone out, is it just as loud?? Just curious
