TTP Equalizer Cam Hits 438rwhp
Old Apr 12, 2004 | 02:06 PM
TTPMatt's Avatar
Default TTP Equalizer Cam Hits 438rwhp
We had Michael4034's car in the other day for some suspension items and a 78mm LSX Intake Manifold. Mike's car made 432rwhp in the cold of the winter, so we wanted to re-baseline his car and he made 425.6rwhp/398.1rwtq on the baseline. So he gained 13rwhp and 5.5rwtq from the LSX over his ls6 intake.
This was all done through a Moser 12-Bolt with 4.11 Gears.
Curve looks real nice. He gained hp/tq across the board, not just peak. If we had the weather of the winter months back, he should have topped this number no problem. This was done with no dyno tricks, both belts on the car and on a 65 degree day.
His modifications are as follows:
- TTP Stage 3 Cam Package - Equalizer V.1 Camshaft w/ ASP Underdrive Pulley
- Kooks 1 3/4" LT Headers w/ Offroad Y
- Bone stock LS6 heads -- no valvejob, no porting, no polishing
- Moser 12-Bolt with 4.11 Gears
- Borla Catback, all the minor bolt-ons, lid, filter
- Matt
Old Apr 12, 2004 | 03:42 PM
CHRISPY's Avatar
nice numbers
Old Apr 12, 2004 | 04:12 PM
2MCHPWR's Avatar
congrats!
do you think the 90mm version would have yielded even greater results?
did you use a stock t-body with the 78mm intake? if you use 90mm intake, do you have to switch t-bodies?
Old Apr 12, 2004 | 05:18 PM
black_knight's Avatar
You should include the RPM's on that dyno chart if you don't want us to suspect foul play...
Old Apr 12, 2004 | 06:15 PM
Scoobie's Avatar
Nice #'s Matt. I cant wait til my car puts those to shame Hmmm, LSX intake...... ( homer simpson )
Old Apr 12, 2004 | 06:46 PM
Michael4034's Avatar
I,ve got RPM's on my graph, & I,m pretty sure my track times are comparable to most head & cam cars.
Old Apr 12, 2004 | 06:49 PM
Michael, if this is the case, could we SEE the graph with the RPMs, please? The current one that is posted in this thread does not have them, in case you didn't notice.
Old Apr 12, 2004 | 07:03 PM
If I wasn't such a computer retard I,d be happy to post my graph.
The bottom line is I,m very pleased with the car. It's streetability is amazing, & the low end torque is great. I drive nitto drag radials on the street and have no problem smoking the tires from a roll. I hope to have some new track times this week with the new mods.
Old Apr 12, 2004 | 07:56 PM
x phantom x's Avatar
STF veteran / 10 second club
Why so skeptical?
Old Apr 12, 2004 | 10:57 PM
black_z's Avatar
What are the specs of the equalizer cam?
Old Apr 12, 2004 | 10:58 PM
pdd's Avatar
pdd
sounds like a mint setup
Old Apr 13, 2004 | 09:31 AM
TTPMatt's Avatar
black_knight: We updated the graph with RPMs.
The tach wire wasn't working well that day, as you can see it skips out a few times on us. We also only pulled to 6500 on this run, the cam still makes power above that.
The specs are around 230/240 on a 112lsa. It is only available in our installation packages. The full package with dual springs, titanium retainers, double roller timing chain, installation, fluids, gaskets, dyno tune is $1975.
- Matt
Old Apr 13, 2004 | 01:36 PM
bryan c's Avatar
aren't hp & tq supposed to cross @ 5252 rpm?
Old Apr 13, 2004 | 01:42 PM
P Mack's Avatar
Not if the torque scale is different, which it is.
Old Apr 13, 2004 | 03:59 PM
Jim Mills's Avatar
Exactly they are different scales for HP and TQ
Old Apr 13, 2004 | 04:35 PM
This cam isn't available for sale unless the person buys the entire package with installation? Why would you do that?
Old Apr 13, 2004 | 06:18 PM
TTPMatt's Avatar
Numerous reasons actually.
1 - With this big cam, we'd rather know that the tune is perfect. It is a hard cam to get to idle perfectly. We'd rather not be responsible for mishaps or poor drivability that is accounted towards our cam.
2 - The cam is pretty big in size, it does not require flycutting, but for people that try to throw this on a car with milled heads, etc. and they smack a valve... You get where I'm going with this, more of a liability reason.
Bottom Line... The cam is big and nasty. If it gets done by us, we know the install is done right and we will have no bad publicity because of a mishap.
- Matt
Old Apr 13, 2004 | 07:22 PM
Those are acceptable reasons.
Good luck with the cam.
Old Apr 14, 2004 | 06:08 PM
Scoobie's Avatar
I cant wait to here this Big Nasty Cam in my car
