Looking to do a 500RWHP N/A build
First, I'd look into a new exhaust setup. Something better like ARH/Kooks/SW and/or at least a true dual. Cant cut corners to get 500rwhp.
AFR/PRC/TFS ported heads/ported FAST 102/102mm TB/custom huge cam/agressive tune all the boltons UDs/ram air/big LID/bigger MAF/light flywheel/stage3+ clutch/9inch rear end/etc.
..and 15000+$ to spend. Talk to any good sponsor and tell em youre serious about it and they will provide you all the shiny parts!!
But if I can give you an advice, have realistic goals, do you prefer to have an all out race car or something thats street friendly? The best way is bigger cube. 418-440ci FTW!
Not bashing texas speed or anything but after doing lots and lots of research, I dont see why the hell youd buy their PRC castings. They are $2200+ shipping and tax. Trick Flow and AFR are right at $2400 and still beat them all the way across the board with flow numbers, and still bottom line, a better head.
408 stroker TFS 235CC heads, fast 102/102 custom cam
Ported super Vic with a 4150 tb, not an elbow style
Very good ported heads
13-1 compression
Mid-high 24x or bigger duration cam with mid .650ish lift (or greater)
Proper springs and valves
Quality 1 7/8 headers
Perhaps an ewp and under drive pulley.
I don't have ALL bad to say about TSP, this is one of many factors than made me go with their 237 casting. Even though I am upgrading the valves:
http://www.hotrod.com/techarticles/e...t/viewall.html
I answered in the other thread, its do able but it takes the right combination of parts, the right dyno and a good chunk of $. No amount of HP should be left on the table with a max effort setup like this, and more than likely OP will have to flycut the pistons. Its alot more common to more cubes, op.
It will definately be a challenge, but has been proven it can be done.
My stock bottom end 346 made 440rwhp w/AFR205s/MS3 cam/Fast 90/1 3/4 Headers/True Dual exhaust/Yank 4000 stall (locked)
Underdrive pulley,e water pump, fast intake,Vic junior or sheetmetal intake(ur choice on intake) and cross ur fingers
** I should have went with a procharger from the beginning. **
It may make 500 on one dyno and not on another
